S1 Wing Mirror, Cluster and Panel Cuts WANTED!
nimspringus
Post by nimspringus »
Hi,
As above, I'm looking for a passenger-side wing mirror and a diesel auto instrument cluster for an S1.
I'm also after front and rear bumper brackets (cuts) as all four of mine are completely rotted out!
Thanks!
Re: S1 Wing Mirror, Cluster and Panel Cuts WANTED!
What part of the cluster do you need, each gauge is separate. The only difference between manual and auto clusters is the gear selector Lcd display, for the auto and the back board that drives it.
I would just fabricate new bumper brackets, the chances of finding some in useable condition is very slim.
nimspringus
Preferably just looking for a whole unit as not much on mine works at all, not even the backlights!
The backlights are just regular incandescent bulbs, it's unlikely the cluster has caused the failure, much more likely the dimmer rheostat isn't connected.
If it is a failure of the circuit, it is most likely to be the solder joints on the connectors has cracked joints.
Due to the backlights being on all the time the ignition is on, it's common for many of the bulbs to be burned out.
Southerneruk
Post by Southerneruk »
Where about's are you nimspringus, I have loads of parts for mark 1, turbo, auto, estate. Come on down to west Southampton and have a look though what I have
nimspringus
I'd honestly love to, but I'm in Edinburgh so that's almost as far away as it's possible to get!
