I need centre caps for a set of wheels that I am fitting to my XM. Either plain or with chevrons.
Note that the centre caps fitted to post-2000 Citroens, although having the same major diameter (60 mm), have a larger minor diameter of 55 mm (c.f. 50 mm) and shorter lugs, and just don't fit.
The original part number of the plain silver caps seems to be 9660271777, but there may be other compatible part numbers.
Wanted 4x 60 mm Center caps for Xantia/BX/XM alloy wheels (also 90s Peugeots)
Re: Wanted 4x 60 mm Center caps for Xantia/BX/XM alloy wheels (also 90s Peugeots)
If all else fails, here's 2. https://www.ebay.co.uk/itm/186770347774 ... d107066b1f
GYRP appear to be making them, presumably in 3d print. https://www.gryp-3d.com/gb/citroen-xant ... inish.html
I must have the wrong part number, as the ones I need are definitely 60 mm major diametder, but the depth of those look correct. The wheels I am fitting are Peugeot 605, so I presumed that they would share centre cap dimensions with Citroen.
I thought the finish of the 3D printed parts looked a bit rough.
Cretustf_21
- Orga / RP numbers: VF7Y3AX0000AX6141
6050 - Location: Redditch
If you need them in 3D printed, I can help.
I did a set for my xm with floating badge, but the base I can modify and make it plain if needed
