steering ram
Southerneruk
steering ram
Post by Southerneruk »
I need new seals for the steering ram, any one know where I can get these seals from
Degens
Re: steering ram
Post by Degens »
maybe my steering rack has it?
Re: steering ram
All the ps rams are the same, so any exchange one will do.
I believe the end rubber return gaiter is available, but can any more of the ram be disassembled?
Southerneruk
Re: steering ram
I know the rack can not be fully dismantled, I had tried, I thought I had a spare ram, but can not find it, but definitely have a leak though the seal
Southerneruk
Re: steering ram
Can you check for me Degens
Re: steering ram
The ram will have a small amount of allowable leak, which is collected and returned to the reservoir via the rubber collar, P/no 95640212
Item 8.
http://ci.catcar.info/citroen/img/pr/09/00044509.jpg
Southerneruk
Re: steering ram
This is more than a small amount, it drips when not in use, think I might have damage it when doing that gaiter replacement
Re: steering ram
Where is it leaking from, a split return pipe fitting will leak a lot when not running, as the complete pipe empties.
Southerneruk
Re: steering ram
I have a drip on the ram push rod that connects to the end of the rack
looking at the rubber cover on the end of the rack, it does feel a bit on the hard side for rubber
Re: steering ram
The return gaiter is the active return from the cylinder, it doesn't create the seal for the rod. It sounds like you do indeed have a leaking ram.
