I have for sale two (2) strut tops from a 1994 diesel estate. They are in good useable condition and could be used for spares, fitting or exchange. I no longer need them and if anyone wants them am happy to take £40 for the pair plus postage. Had them on eBay ages. I have cleaned painted and wax oiled them. Pictures on eBay at present.
Also have one strut off same car and a pair of calipers that had very little use after I fitted a complete seal kit. Some hydraulic valves such as the safety valve sort of flat looking valve from front of car. Have two brand new boxed series 2 mirror frames that's complete metal part with motors less glass and plastic cover £15 each. Two suspension electro valves with working solenoids. I checked the diodes with a 9 volt battery
Good used strut tops and strut for sale.
Onion Johnny
- Orga / RP numbers: RP7302 Silver 01/1997 Series 2 Hatchback. 2.0 TCT
Southerneruk
Re: Good used strut tops and strut for sale.
I could do with one, if the rubber is intact
Onion Johnny
The main rubber dome is fine the thin outer skin is missing but it's only cosmetic. All that outer ,part was cleaned up painted and wax oiled. I want to sell both as they are a matching pair and I am having a clear out. I doubt you will find one for the price I'm asking. If you want perfect looking strut tops you will need to get them remade but at least you don't need to pay a surcharge if you use mine or your own.
Southerneruk
Ok I give it a miss this time round thanks
To confirm, are these 16mm, or 18mm centre hole and short, or long skirt?
Do you have any images, especially the underside rubber?
Onion Johnny
The thread size is 18mm the skirts are short type. I have them on eBay at moment with lots of photos of both including underside. If you need more I can email them to you as not sure how to upload photos on forum. I can post more on to eBay as I know how to do that.
