Clearout
Clearout
This lot was originally posted in January. No-one was interested. Due to circumstances it all has to go.
Car's have gone, storage has gone, all parts old and new are going. All parts are plus p+p, all open to offers.
Payment by PayPal, Bank Transfer or cash on collection.
The subframe and brakes are heavy and will be more expensive to deliver.
XM Vapour blasted rear subframe
S1 Clarion PU-9358A
Unknown working condition. Never tested. Might work, might not.
S1 Clarion PU-9594A
Peugeot Citroen Elit
TEP 92
P 101064
No 5138
1x Peugeot Cassette
1x Citroen Cassette
Only the 8 pin connector and clips
No expansion port for later cars
S1 XM PVC Windscreen side strips
S1 Door Mirrors in Hurricane Grey
Delco Peugeot Citroen Ducellier Distributor
Pair S1 Headlights
S1 Original Rubber Rear Mudflaps
S1 Digital Heater Control
S1 Indicator/Wipers Stalk
S1 XM Ignition Barrel, Wiring and 2 keys
Brand New
3x XM Xantia Door Locks
Brand New
S1 Xantia Door Mouldings x4
S1 Xantia 4x door strips
Stainless steel replacements that have been in storage for years. In very good condition but have become partially separated from the backing. Need removing from the backing, reattaching and glueing.
Complete exhaust for Xantia 1.9td hatch
4x 14" steel wheels with good 175/65/14 tyres
Complete front brakes for XM, Xantia, BX and 405 and 605.
Brand new discs and pads. These do have water rust from storage. Discs are 275mm diameter. Refurbished calipers and carriers. These have been powder blasted, painted and coated. All the seals for the calipers are brand new, just need fitting. Connectors and drop links as well.
No prices attached, all are subject to offer either on this thread or pm. If you require photos I'll do my best but time is not my friend atm.
Also available is a Diagbox 7 set-up. Everything included but needs Patch attaching to work.
S1 Clarion PU-9358A
S1 Clarion PU-9594A
TEP 92
P 101064
No 5138
1x Peugeot Cassette
1x Citroen Cassette
Pair S1 Headlights
Brand New
Brand New
Re: Clearout
Any prices, in particular for the Elit and Diagbox?
Re:
I don't recall having any conversation regarding your Elit and am unaware of anything to do with an expansion port. Is that the 30 pin connector?Eddie nuff wrote: Sun Sep 28, 2025 11:50 am I've deliberately not given any prices due to the need to get rid. You said the Elit wasn't good enough as it didn't have the expansion port.
Rough prices:
Elit £50, Diagbox £150 but I really am open to offers on all the parts.
What Xm will it work on, Series1, 2, engine and ABS ECU's?
Again is the Diagbox functional?
Re: Re:
No 30 pin connector.
Series 1 up to '91 I believe.
Diagbox starts but will not work until the patch is attached.
Julianw
- Orga / RP numbers: 4937
Re: Clearout
Some guys local to me are restoring two BXs atm and have need of new front brake pad wear harnesses (both sides) and a matching pair of drop links. Do you have these, and are the drop links new?
Thanks
Thanks
Southerneruk
Re: Clearout
S1 Headlights x2 pairs, first are they for the UK roads and second what are the plastic inserts like, a photo of the lights would be handy to see the discolourations of the plastic inner lens
Southerneruk
Re: Clearout
How much would except for a driver side light
