Looking for Ac hose
Cretustf_21
Orga / RP numbers: VF7Y3AX0000AX6141
6050
Looking for Ac hose
Post by Cretustf_21 »
Did anyone have a good 2.0 Turbo S1 Ac hose?.. the one from compressor to driver side condenser inlet?
Mine isn't good the thread in the coupling and is over lapping the thread at the condenser outlet.
I think its part code is "Freon tube - 96066792 or 6457 H7"
Need it to finish asap the car. Thank you.
Re: Looking for Ac hose
Best to go to a local A/c specialist and have one made up. A hydraulics supplier may be able to make one.
Cretustf_21
6050
I will try to find someone which are accepting to do that, as my local its funny and he want the car in his shop
Cretustf_21
6050
Same guy which weld the condenser, chopped the pipe tube( steel) and cleaned the thread from alu residues and weld it back. All fitted now, I can hear the engine running, Yayyy, but the nut from alternator pulley come off( they didn't tighten properly 😡) now need to fint the way to tighten it properly without stripping again😬
I think the only way to tighten the alternator pulley nut will be to counter-hold the fan.
One would think the nut would self tighten being right hand thread.
Your engineering contact certainly sounds useful.
Southerneruk
Post by Southerneruk »
I sent all my AC stuff to gwolfski in NI, you could ask him if he will need this pipe as it will be spare for him
Cretustf_21
6050
Southerneruk wrote: Sun Jun 30, 2024 9:44 am I sent all my AC stuff to gwolfski in NI, you could ask him if he will need this pipe as it will be spare for him
Atm is sorted, waiting to have a day off to go and check what I've done.
Probably for future I will think for a new one
Thank you
