1994 VSX CT auto BREAKING
Citjon
Orga / RP numbers: 8032
Post by Citjon »
Paint code ESYCR Forest Green
Parked up since 2012 and stored outside so bodywork is poor, as you'd expect. Outer panels are straight so might be salvageable. There is severe corrosion in the sills and floor areas and therefore it's not really viable to save unfortunately.
The mileage is around 150k, engine runs well and it drives, although a suspension pipe has blown so can't test gearbox thoroughly. I do have the service book - it was serviced annually / every 9k at Godfrey Davis up to 90k then at an independent specialist in Lincoln. Registration is M753EWK.
I would like to keep the wheels, front indicators and headlamp washers but everything else is available. If anything specific is needed I can check condition and provide photos.
It does have an original remote control in working order with another spare key. Interior is grey cloth - a bit damp in places but would probably clean up OK. Gear lever is no good.
Can post smaller items alternatively collection would be from Market Rasen or Louth in Lincolnshire.
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
TomSaintJames
Re: 1994 VSX CT auto BREAKING
Post by TomSaintJames »
Hi Citjon, I'm looking for a turbo, manifold, oil/coolant lines and boost pipework. Are these available still and would you post? I'm waaay down south in Somerset.
Thanks, Tom.
Citjon
Post by Citjon »
Hi Tom,
All those parts are still on the car but I have had an enquiry from someone about the complete engine.
If that doesn't come to anything I will let you know and I'll look into postage costs etc.
Many thanks,
Jon
89 CX25DTR T2
72 D Super 5 Black
TomSaintJames
Many thanks John 👍
Southerneruk
Post by Southerneruk »
Do you still have the 2 led open doors & fault and clock either side of the steering wheel
Citjon
Post by Citjon »
Yes they are both present, I think the clock is OK but the left not so good. I will try to check them this weekend.
89 CX25DTR T2
72 D Super 5 Black
Southerneruk
Ok thanks
TomSaintJames
Citjon wrote: Tue Apr 30, 2024 3:35 pm Hi Tom,
Many thanks,
Jon
Any update on this Citjon?
Citjon
Post by Citjon »
Not yet, I should find out later this week though
89 CX25DTR T2
72 D Super 5 Black
Citjon
Post by Citjon »
Southerneruk wrote: Wed May 01, 2024 9:55 am Do you still have the 2 led open doors & fault and clock either side of the steering wheel
I've tried adding photos but keep getting an error message, so will pm you.
The clock display is quite dim but looks to be OK. The screen on the left message display is scratched but the digits look complete. I'm not sure if it could be changed or maybe polished out?
89 CX25DTR T2
72 D Super 5 Black
