V6 prv parts to go..
Assorted parts for prv 12v and some 24v prv v6 engines.
5x top rad hoses. 2 with hose back to oil cooler
Lhm tank to pump feed hose
Air intake hose air box to throttle body
2x Rad bottom hose.. water pump outlet and to expansion bottle 1 with a open T junction on the pipe to the expansion tank
Pump to regulator hp feed pipe
2x front bank to rear link pipes
2x sets R134a air con pipe systems
2x Idle valve pipe to air cleaner box
3x dizzy upper covers
3x Idle valves
5x ignition leads 12v
Heat shield for under engine above front to rear link pipe..
Heater matrix to engine pipes for 12v ..
24v Ht leads
More to add .
Can go as a job lot.. but really need to clear it out.
sageman
Re: V6 prv parts to go..
Post by sageman »
Is any of this still avaliable?
1976 Reliant kitten
1998 Peugeot 306 GTI-6
1993 XM sei V6 RP 5876
Some of it.. what are you after..?
sageman
Post by sageman »
Tank to pump feed hose
Dizzy upper cover
Idle valve
1976 Reliant kitten
Can do those.. ill pm you..
