Wanted: Hydractive electrovalve wiring loom connector.
Wanted:
Electrovalve wiring loom connectors (male and female) and short lengths of wire, from a H/a loom for Hydractive 2 car.
This is the connector that is situated on the right strut tower under the sphere.
I should have one for H1 system, but if anyone has one on a scrap loom, that might be useful also.
Re: Wanted: Hydractive electrovalve wiring loom connector.
Not sure what you mean will.. I've a. Number of looms from cars.. Sadly no spare cars. Anymore Nd no doubt what you wanted was on the last car that wentast month..
I want to make a pass through loom, so need both connectors and the wires to solder together.
The intention is to use it as a break out loom for testing H/a operation, by adding some Led's and test points.
H/a1 and H/a2 need a different loom due to the additional electrovalve on H/a2.
Another way would be a breakout at the H/a Ecu, but that would need the connectors from a scrap Ecu and the loom connectors.
I've never known a H/a Ecu fail, so don't have a scrap one.
I've plenty of ecus.. The suspension loom was still on the last car to go too.
I have S1 looms from the two early cars I stripped bare about 4 years ago or so. I'll come across them or may have already without realising it. I'll check the looms boxes at the unit this week as little man is back to school tomorrow..
