Wanted
Part No : 6542CY and CZ....part No 10 + 3 (Maxi fuse holders)
There are two fitted to Y4 cars so id anyone is breaking one (front left side of the engine bay just next to the fuse box)
Am away from Parts access at the moment, but I think both the upper and lower parts of the maxi fuse are still available from Citroen, but Iirc the lower part does not come with any fuseholder contacts, just the plastic housing.
I think the contacts were part of the car's wiring loom, but I could be wrong. You might be able to improvise with some large push-on female blade connectors.
The maxi fuse units will click-fit (slide) onto one another, to extend the line.
Chris 1996 XM 2.5TD Exclusive RP7165 Polar White 1992 BX19D Millesime RP5800 Sable 1989 BX19RD Delage Red Deceased; 1998 ZX 1.9D Avantage auto Triton Green Company car 1998..2001; 2001 Xantia 1.8i auto Wicked Red Company car 2001..2003
The reason I want these is exactly that, to extend the two already there for the F2 fuse and keep it all looking original rather than add an after market fuse box or in-line holder.....I have "plans" for the extra one
New (original) fusebox available from Cit sfair, but probably a good idea to fit something more durable for F2, rather than another same.
I think I have some brand new spare maxi-fuse 2-part holders at home, if you're stuck. PM if needed.
Have agreed a "sale" from marc61.....will PM if there is a problem ...cheers.
Yes, fuse box is but the Maxi-Fuse single holders are not (so I am told by a Citroen dealer....but we KNOW a lot of them lie to old car owners)
The plan is to make the F2 slot power feed for the LED Drl's as it is only live when the engine is running and the contacts are still "OK" for a low power demand. They have become hot and showed a lot of corrosion (he reason for the over-heating but are now cleaned and working)...... so I --need-- to do the modification as a preventative measure rather than having to fix a failed holder.
