XM NOS parts for sale
roggenfaenger
XM newbie
Orga / RP numbers: XM 3,0 V6, 1993
D Super 5, 1973
CX 2400 GTi, 1982
CX 25 Prestige, 1984
BX 16 TRS, 1984
CX 20 RE Break, 1986
Xantia 1,8i, 1994
Post by roggenfaenger »
Hello
I have bought quite a few NOS-parts from a Citroën dealer recently. Mostly CX, BX and XM parts, some Xantia and AX.
Here is a list of XM parts. There will be more, I will just have to go through all pieces.
Shipping form Germany is available for most of the parts except the larger exhaust-pieces.
Get in touch if me if you are interested in one or another gem :D
... and kindly excuse the German wording for the description of the parts.
Cheers Michael
95291415 Zierleiste Scheibenführung Tür hinten rechts
95651041 Belüftungsbetätigungsplatine
KN 43802 XM Leichtmetall-Felge
2105.20 XM Führungshülse Ausrücklager Getriebe MG
4066.29 XM Lenkmanschette links reserved
96024696 XM 2,0 flex. Hydraulikrohr Mengenteiler - Druckspeicher
96161677 XM Kabelsatz Verschleißanzeige Bremsbeläge reserved
95656489R / D7R8 AT-Anlasser für XM Diesel (Saugdiesel und 2,1 TD) reserved
0532F4 Schwungrad für 2l und Turbo, BVM, Y3 und Y4
96131150zl Außenrückspiegel links elektrische Verstellung
96131143zl Außenrückspiegel links manuell
96040565 Türverschluß links hinten
96051825 Federkugel hinten, non-Hydractive
Last edited by roggenfaenger on Thu Jun 17, 2021 7:27 pm, edited 2 times in total.
Re: XM NOS parts for sale
Post by White Exec »
google translated...
95291415 Trim strip window guide door rear right
95651041 vent control board
KN 43802 XM light alloy rim
2105.20 XM guide sleeve release bearing gearbox MG
4066.29 XM steering boot left
96024696 XM 2.0 flexible hydraulic pipe flow divider - pressure accumulator
96161677 XM cable set for brake pad wear indicator
96070983 XM ignition cable 2.0i
95656489R / D7R8 AT starter for XM Diesel (suction diesel and 2.1 TD)
0532F4 flywheel for 2l and Turbo, BVM, Y3 and Y4
96131150zl Outside rearview mirror left electrical adjustment
96131143zl exterior rear view mirror left manual
96021679 Rear exhaust silencer
95650970 indicator front right
96021679 rear silencer
96040565 door lock, rear left
96051825 Rear spring ball, non-hydractive
roggenfaenger
XM newbie
D Super 5, 1973
CX 2400 GTi, 1982
BX 16 TRS, 1984
Xantia 1,8i, 1994
some more parts ... plus DeepL-Translation ;)
95663042 Federzylinder links
95663043 Federzylinder rechts
2050T4 Kupplungs-Kit
09425 Hydrostößel 2,1 und 2,5 TD
1616054080 Glühkerzen
96051826 Hydractive-Federkugel vorne, 2l und 2,1TD, bis Orga 5938, 400ccm/55bar
95669124 Hydractive-Federkugel vorne, V6, ab Orga 5929, 450ccm/75bar
6113Y4 Tachowelle
95663125 Ölstandsmessempfänger BVA mit Anzeige Reichweite
95291400 Zierleiste Scheibenführung links, Limousine
1628R0 Beschleunigungspotentiometer
95291471 Scheibe Tür hinten links, getönt
0197C8 Motordichtsatz 2,0 Benzin
0209H1 Zylinderkopfdichtung 2,1 Diesel
95663042 Spring cylinder left
95663043 Spring cylinder right
2050T4 Clutch kit
09425 Hydraulic tappet 2.1 and 2.5 TD
1616054080 Glow plugs
96051826 Hydractive spring ball front, 2l and 2,1TD, up to Orga 5938, 400cc/55bar
95669124 Hydractive spring ball, front, V6, from Orga 5929, 450cc/75bar
6113Y4 Speedometer cable
95663125 Oil level gauge receiver BVA with range indicator
95291400 Trim strip windscreen guide left, Sedan
1628R0 Acceleration potentiometer
95291471 Window, rear left, tinted
0197C8 Engine gasket set 2.0 petrol
0209H1 Cylinder head gasket 2,1 Diesel
Just to point out for things like clutch cable and speedo cable are these items for LHd cars or are they all UK aquired items there for suitable for UK RHD cars..?
ralphturenne
Post by ralphturenne »
do you have spark plugs wires and spark plugs? i am also looking for the main key switch.
Main key switch as in ignition key on the steering colum..??
roggenfaenger
XM newbie
D Super 5, 1973
CX 2400 GTi, 1982
BX 16 TRS, 1984
Xantia 1,8i, 1994
ralphturenne wrote: Tue Jun 22, 2021 8:34 pm do you have spark plugs wires and spark plugs? i am also looking for the main key switch.
Hi!
I have three or four sets of spark plug wires (have to check if BX or XM). For what model? No spark plugs. A used main key switch is available.
Ralphs car is a Prv6-12v.
HT leads for those are readily available.
ralphturenne
those would work for me if they are a perfect fit for my car. Let me know how we can do this. I am still looking for the spark plugs and wires numbers. I am in the US any other parts i can substitute for the original please let me know as it would save me time.
thank you guys
roggenfaenger
XM newbie
D Super 5, 1973
CX 2400 GTi, 1982
BX 16 TRS, 1984
Xantia 1,8i, 1994
ralphturenne wrote: Wed Jun 23, 2021 3:14 pm I am still looking for the spark plugs and wires numbers.
The spark plug wires for the ZPJ-engine are numbered 5967 H2,
the spark plugs are numbered 96 145 071, replaced by 5960 J8; these are EYQUEM - RFC58LS3
