Wanted....s2 Front fog lamp/left
Stickfinger
Post by Stickfinger »
The lower bumper ones....at worst a glass for it but a complete unit would be better as the rot has killed the reflective surfaces.
Re: Wanted....s2 Front fog lamp/left
EthanR is still advertising breaking his 2.5 and may still have those.
These Mk 2 ones have the front glass glued to frame making recovery very difficult.
There are two versions, the cut down one has the fog lamp section left empty.
The damage to the fog lamp silvering is very common.
The fog lamp reflector also tends to drop off its adjuster mounts with no way into the unit to refit it.
My experience is that recovered ones need careful checking for condition as very few are worth buying.
DownUnderXM
Orga / RP numbers: RP 8603
Post by DownUnderXM »
Ouch! That sounds like the ones I bought! I just assumed that they would be constructed like headlights, allowing me to use the lenses if mine get damaged...
Shake them. If they rattle then the fog lamp reflector is loose.
Look in the front and you can see any brown area where the halogen bulb has burnt the silver off the reflector
A few years ago I agreed to send a friend a replacement glass to fix his broken light.
Had to cut the plastic case away in bits to recover the glass.
Decided not to part with any more as the problems make them a rare item.
As made the upper and lower surfaces of the reflector are brown, due to no silvering.
Only the curved bowls are reflective to control the light output.
EathanR
Post by EathanR »
I have a pair for sale. Believe on eBay listed for £40 but happy to take £36 outside of eBay. In good condition, if you look them up on eBay you'll find the listing (or should).
Edit - Those prices include postage to a UK mainland address, but can post worldwide
I have checked and on Mk 2 fog lights they are fully silvered.
Any browning on the reflector is damaged silvering and not by design.
Post by White Exec »
S2 here, silvered parabolic around the lamp, and flat silvered top and bottom.
Degens
Post by Degens »
Is this perhaps what you are looking for: https://www.ebay.co.uk/itm/224411717835
Contact me if it is.
Best wishes,
Hans
