Hi Jon
Could I have the covers on the Maxi fuses by the main fuse box and the plastic cover that covers the nut on rear wiper please?
Oh also the coolant expansion tank if still available!
Cheers
Steve
1994 VSX CT auto BREAKING
SteveLP
Re: 1994 VSX CT auto BREAKING
Citjon
- Orga / RP numbers: 8032
Hi Steve,
Sorry but the expansion tank has already gone. I think I've got the other bits, is it the fuse part with the yellow locking bits?
Regards,
Jon
Regards,
Jon
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
89 CX25DTR T2
72 D Super 5 Black
wesacosa
as per the PM about window clips....
the peg arrowed yellow runs through the glass and the removable clip arrowed in blue holds it in place
The peg attachment is really flimsy though so can snap easily as both of mine have
1997 2.1 TD Manual (XUD11BTE, RP7367). Slowly getting it brought back to life
SteveLP
Hi. On your photo the big fuses are next to the main fuse box in front of the air filter housing. It is the covers I need but you could just unscrew the lot and I'll have it.
The rear windscreen wiper nut-cover should just pull off.
If the passenger side windscreen washer bottle is there that would be nice to have too, but probably a pain to post. So maybe just the washer motors?
Other thing I'd like is the accumulator/regulator as mine is dripping from somewhere!
Thanks
Steve
Thanks
Steve
Citjon
OK I'll have a look at these next time I'm at the workshopwesacosa wrote: Fri Aug 16, 2024 7:32 am as per the PM about window clips....
89 CX25DTR T2
72 D Super 5 Black
89 CX25DTR T2
72 D Super 5 Black
Citjon
I agree about the washer bottle, although I could send it separately? The other option is to meet at Chevrons if you're going?SteveLP wrote: Fri Aug 16, 2024 7:41 am Hi. On your photo the big fuses are next to the main fuse box in front of the air filter housing. It is the covers I need but you could just unscrew the lot and I'll have it.
Thanks
Steve
I've already sold the regulator but might have another one, although I cannot vouch for the condition.
89 CX25DTR T2
72 D Super 5 Black
89 CX25DTR T2
72 D Super 5 Black
If there isn't regulator available, a new set of O rings normally fixes any leaks.
Sphere seal: 5272 15 : 37,4 * 42 * 2,6
Cut out O ring: 96157730 : 37 * 33 * 1,9
Cut in o ring: 96157736 : 29 T2,7
Pressure relief bolt O ring: 4026 82 : 6-TO 1,9
I might be incorrect here, but don't sinkers and anti-sink have different number of pipes out of the regulator, as there is no longer a connection to the Fdv.
Early series 2 one is 5274 15
The one for the Es9j is 5274 18
see: https://www.catcar.info/citroen/?lang=e ... aWVyPT0%3D
Citjon
Managed to extract it without any breakages!wesacosa wrote: Fri Aug 16, 2024 7:32 am as per the PM about window clips....
89 CX25DTR T2
72 D Super 5 Black
89 CX25DTR T2
72 D Super 5 Black
- m0rda
- Orga / RP numbers: 96 3.0 V6 VSX Auto, 7133, Diravi, Green
94 3.0 V6 Exclusive Auto, 6581, Green - Location: Congleton
Have you got headlight washer jets? I am interested in left-side one.
Both headlight washer caps are of interest, too.
m0rda
1996 XM 3.0 V6 VSX Auto RP7133
Citjon
I need the covers for my car but might have spare washer jets.m0rda wrote: Thu Aug 22, 2024 11:19 pm Have you got headlight washer jets? I am interested in left-side one.
89 CX25DTR T2
72 D Super 5 Black
89 CX25DTR T2
72 D Super 5 Black
