1994 VSX CT auto BREAKING
Citjon
Orga / RP numbers: 8032
Re: 1994 VSX CT auto BREAKING
Post by Citjon »
Citjon wrote: Fri Jun 21, 2024 7:05 am
Southerneruk wrote: Thu Jun 20, 2024 9:52 am Do have the bits between the aerial and car roof, need to be careful when removing it as an expansion peg that needs to be taken out first, you can get to that from inside the car and removing the light panel where the motor and gearing for the sunroof, remove the peg before removing the cable and undoing the nut
They should still be on the car, I'll have a look
I've dropped the sunroof motor but can't see the underside of the aerial. Did you mean the complete sunroof mechanism?
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
The aerial is accessed via the centre sun-blind.
Citjon
Post by Citjon »
Thanks Will, I thought it was a bit extreme dropping the whole thing just for the aerial.
89 CX25DTR T2
72 D Super 5 Black
Southerneruk
Post by Southerneruk »
Follow the aerial cable,
wesacosa
Post by wesacosa »
Hi. Did you get a chance to look at the side window channel plastic clips to see if they are in a usable condition?
1997 2.1 TD Manual (XUD11BTE, RP7367). Slowly getting it brought back to life
Citjon
Post by Citjon »
wesacosa wrote: Sun Aug 04, 2024 4:36 pm Hi. Did you get a chance to look at the side window channel plastic clips to see if they are in a usable condition?
I haven't yet but the door card is off so I'll try and get a look at it this week. How many clips do you need?
Are you still after a NSF window regulator as well?
89 CX25DTR T2
72 D Super 5 Black
wesacosa
Post by wesacosa »
one clip would be great but I'd probably take a second if you had it. I could potentially use a working passenger front regulator too depending on price (I think mine just needs a new cable but given thats a bit of a fiddly job I could be persuaded to get a working replacement 😂)
Southerneruk
How did you get on removing the plastic bits and base to the ariel, you have the bit with the nut and bolt, and about an inch behind that you have an expanding lug, it is this bit you need to be careful with, it breaks very easy if you do not see it or realise it is there
Citjon
Post by Citjon »
I had a go but the light wasn't very good. Hoping to get chance this weekend to remove a few other bits
89 CX25DTR T2
72 D Super 5 Black
Citjon
Post by Citjon »
wesacosa wrote: Mon Aug 05, 2024 9:29 pm one clip would be great but I'd probably take a second if you had it. I could potentially use a working passenger front regulator too depending on price (I think mine just needs a new cable but given thats a bit of a fiddly job I could be persuaded to get a working replacement 😂)
Window regulator and clip removed today if you would like to pm me. Just need to check it works.
89 CX25DTR T2
72 D Super 5 Black
