This is one of the cheapest ones i found but quality is unknown
Turbo oil return pipe + O/S/F Strut Pipe
Re: Turbo oil return pipe + O/S/F Strut Pipe
I think I have seen those available for £9.99 post paid from a UK source.
Will check and add details.
Ebay item 371906842767.
Search by p/n 95050399, there are loads available.
You don't need a new clip unless you damage the old one removing it. The trick is to undo it using proper "pincer" type pliers. The retaining barbs and safety clip remain intact.
Degens
I am looking for a n/s strut hydraulic feed pipe for HLM fluid. Not the one I previous mentioned.
Best wishes, Degens
Best wishes, Degens
You will be very lucky to find the part other than second-hand and I would suggest contacting Edwards & Son at Billericay, Essex, who supplied me with one not so long ago. Regards, Matthew T.
Talk to SGS at Dunsfold, just outside Guildford - Citroen specialist who have produced new pipework for numerous hydraulic Citroens.Degens wrote:I am looking for a n/s strut hydraulic feed pipe for HLM fluid. Not the one I previous mentioned.
Degens
Thank you for your suggestions White Exec.
I will follow that up!
Best wishes,
Hans
Best wishes,
Hans
