You won't. Your car was Series-2, with electronic speedometer.Degens wrote: Wed Aug 12, 2026 12:14 pm Unfortunately, I don't have that cable anymore it appears! I hope you will be able to find one soon elsewhere.
speedo cable
Re: speedo cable
Southerneruk
Re: speedo cable
I was under the car to double-check where the sensor is located, and yes it is on the gearbox.
Southerneruk
Re: speedo cable
Well that turned out a waste of time, one they sent was not for the XM it is too short
Re: speedo cable
Is that the lower, 485mm, cable?
Do you know which you need yet, upper, or lower?
Southerneruk
Re: speedo cable
I have thought about it and what was sent was none UK car models, European models cars would be shorter than the ones for the UK, the ends are the correct ones, just to short, UK top speedometers cables need to be about 1000 mm long
I thought I said upper cable, um maybe I did not.
