steering ram
Southerneruk
Re: steering ram
Might just take it off and have a good look, if the inner seals can't be done then it will need a total replacement
Degens
Re: steering ram
will check further. The seals I did see, but getting the rack out I have not yet been able.
Southerneruk
Re: steering ram
Just undo everything connecting it to the body, then drop the subframe.Degens wrote: Wed May 14, 2025 5:30 pm will check further. The seals I did see, but getting the rack out I have not yet been able.
Southerneruk
Re: steering ram
It is only 1 nut and 1 bolt that holds the ram in place, plus there are 2 pipes that need disconnected, and the ram will slide out
Re: steering ram
Can you undo those pipe unions in situ and can the ram be removed with the heat shield still in the cavity? Some engine versions don't allow the heat shield to be withdrawn before the rack is out.
Degens engine is out, so access will be easy.
Southerneruk
Re: steering ram
It can be removed, by sliding to the right and then left and then angle downward and pull out, but first you need to have the ram rod push right in, making the whole of the in it shortest length
Re: steering ram
Thanks. I've never tried undoing the feed pipes in situ.
Southerneruk
Re: steering ram
Don't forget to release the pressure first
