XM NOS parts for sale
ralphturenne
Re: XM NOS parts for sale
Post by ralphturenne »
ok thank you
what can we do for the ignition key switch?
roggenfaenger
XM newbie
Orga / RP numbers: XM 3,0 V6, 1993
D Super 5, 1973
CX 2400 GTi, 1982
CX 25 Prestige, 1984
BX 16 TRS, 1984
CX 20 RE Break, 1986
Xantia 1,8i, 1994
Post by roggenfaenger »
Sent u a pm.
ralphturenne
pm?
ralphturenne wrote: Wed Jun 23, 2021 10:24 pmpm?
Private Message.
Check your inbox.
JimHagen
XM newbie
Post by JimHagen »
Hi there!
I am looking for this part for my XM; 96024696 XM flexible hydraulic pipe flow divider - pressure accumulator.
Do you still have the part and if so, what is your price?
Regards,
Hi Jim..
Is that the loop pipe with rubber that fits between the regulator and flow divider block.. If so for what engine have you hot. I have a couple of used ones.
That part fits Turbo-injection cars.
Assuming it is the rubber to metal joint leaking, can't you have a hydraulics supplier fit a new rubber pipe to the existing metal ones?
Ted Yang
XM newbie
Orga / RP numbers: citroen xm 3.0 12v
96142040
Post by Ted Yang »
Does anyone online know where the citroen xm right front shock absorber (95663043) can be purchased? Please contact y4337113@yahoo.com.tw
Thanks!
Ted Yang
Where in the world are you, someone might be able to suggest someone that has one. It is the 23mm rod type.
I would think Q&K classic Citroen would have one. https://qkcitroenclassics.com/
