stunned new 2000 3.0 litre V6 owner
Re: stunned new 2000 3.0 litre V6 owner
Post by CitroJim » Tue Oct 22, 2013 4:30 pm
rustytractor wrote:I feel embarrassed to say I haven't a clue what the differences between a mk1 and a mk2 are.
Don't worry about that Rusty :D I'm you'll soon be enlightened. I'm not going to try as I'm still very new in the XM world.
Now, if it was a question about Xantias then that would be a different matter..
Post by russ92xmsed » Tue Oct 22, 2013 4:33 pm
Differences are subtle from the outside. More obvious from the interior. The mk2 dash is very much like the Xantia.
Post by russ92xmsed » Tue Oct 22, 2013 4:35 pm
CitroJim wrote:I'd love to do an S1 lookalike ES9 V6 Russ...
My wheels of choice would be wobbly webs...
So would I....Italia for me! :D keep the MK2 leather seats though. They are very comfy. :)
Post by Peter.N. » Tue Oct 22, 2013 4:45 pm
I prefer the Mk 2 personally except the flat top dashboard is useful for standing a cup of tea or whatever on. The main differences from outside are the chevrons being in the centre of the grill and script type writing on the rear XM badge on the Mk 2.
Re: Local Citroen specialists / thanks
Post by Dieselman » Tue Oct 22, 2013 5:15 pm
rustytractor wrote:I spend most of my time working on my collection of old cars (1940's to 1980's) so am comfortable attempting most repairs but the suspension on the XM is totally alien to me.
Currently I'm comfortable doing the small jobs that the car requires but would like to have some decent repairing garage details as back-up for when I get lost.
Can anyone recommend honest, reliable repairing garages and parts suppliers in the Ilford, Essex area or reasonably nearby ?
I'd like to thank you all for being so welcoming to a newby - not all forums are the same.
There is nothing special about the suspension system.
Keep the pipes coated in rustproofing, the LHM fluid clean, lubricate the height corrector pivot bearings and when the ride gets hard change the spheres and the system will remain faultless for a long time yet.
rustytractor
Post by rustytractor » Tue Oct 22, 2013 5:44 pm
Dieselman wrote: There is nothing special about the suspension system.
Ah, but having never driven or been a passenger in an XM (or actually any Citroen except my step daughters DS3 last week now I come to think of it....) how do I define "hard" ?
It feels fine to me but I know bugger all about the way they should ride.
What I do know is the suspension goes up and down (I assume) the way it should, the pump sometimes makes a bit of noise on start up (normal ?) but quietens down very quickly and it's a very comfortable and fast place to be. Other than the ball joint issue previously mentioned, there's a little squeak from the steering, another tiny squeak from somewhere under the dash, the odd, very slight suspension creak and what sounds like a relay making and breaking under the passenger side of the dash. Looking at the service history I was aware that the front passenger window stops working intermittently so wondered if there was a relay under the dash which controls this. It's working now but I think only since the noise appeared but could be wrong here.
You know what it's like when you buy a used car - it takes a while to understand it's quirks so I intend to use the car as is, compile a (hopefully short) list of faults and then set about fixing the inexpensive ones first !
For a car that's covered 120k miles it's obviously been very well cared for and maintained, in fact I've just written to the previous owner complimenting him on how he's kept the car and asking for any info he can provide about know issues/quirks and the radio code as it's locked at the moment.
Post by Dieselman » Tue Oct 22, 2013 6:05 pm
You said the ride is comfortable, that says the spheres are good. As the spheres age the ride gets harder and more bumpy.
Eddie nuff
Post by Eddie nuff » Tue Oct 22, 2013 7:27 pm
Style!
rustytractor
Re:
Post by rustytractor » Tue Oct 22, 2013 7:33 pm
Style!
So that means mk2's are more defined but mk1's are more for the purist ?
Post by xmexclusive » Tue Oct 22, 2013 7:46 pm
The clicking relay in the passenger dash will be due to the indicator stalk contacts.
Wear and conductive debris in the grease around the contacts are the standard causes.
If let go on for years the switch most likely start to smoke and then burn out.
Mk 2's if you want to actually use one.
Mk 1's these days are usually well polished driveway ornaments awaiting classic acclaim.
