Hello Chaps....new owner
Re: Hello Chaps....new owner
ahhhh OK. fair enough..
Stickfinger
To whom it may concern....thanks a lot you @@@@@@@@
one 11mm, one 12mm(nylock) = spinning bolts arrrrgggg ?? why use a @@@@@@y Nylock...the plastic melts into the threads !
solution = heat and sacrifice a ring spanner and go over the top/down from the top
Citjon
- Orga / RP numbers: 8032
Very innovative spanner modification! I struggled to reach the standard exhaust bolts on my 2 litre petrol despite crawling around on my back underneath.
Long arms are definitely an advantage.
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
89 CX25DTR T2
72 D Super 5 Black
A crow's foot spanner (on the end of an extension) any help for this one?
I was thinking the reason you couldn't get the nut undone was due to using that weird spanner...
From underneath You can fit a standard spanner onto the bolt head, then use a socket on a looong extension on the nut.
An impact gun will undo these, unless very rusty, in which case saw through the bolt shank with a hacksaw blade and replace.
I assume this is on the car, not the spare engine.
Looks like you cut through the exhaust and took the collar off with the head and turbo.
They are not the proper bolts, which have a bevel under the head, to fit into the countersink in the flange.
Best to buy a new bolt and washer set.
Stickfinger
The flange just came off and needed no help, I still need to inspect it but I expect a failed (poor) weld or a bodge.....at the time I just thought it was how it fitted.....another job to do.
Will take photos later this morning
Stickfinger
What do you think chaps(s's)....weld it back on in situ or take the pipe/box off and do it off the car ?...Does it need a continuous weld or just spot welds to secure ?
The car has a CAT fitted.
continuous. else it will leak gasses??
Stickfinger
I will take it off then, just wondered if the gasket ring sealed it....
The gasket ring only seals the moving ball and socket, not the flange to pipe.
The correct bolts have the bevel to allow them to move, which allows the joint to swivel.
The flat bolts you have may be locking the joint so transferring the movement to the pipe.
Or it could just be rusted through.
