Cheers – Mark W
Informing E-mails
markysimon
Informing E-mails
Every time I post a message on the Forum I tick the box requesting email notification o0f any replies, but such notifications NEVER appear in my Inbox. Which is frustrating.
Can anyone suggest a solution, please?
Cheers – Mark W
Cheers – Mark W
1997 V6 24valve Exclusive
1995 XM VSX Turbo (Deceased)
- raynoon
- Orga / RP numbers: 6043
Re: Informing E-mails
It's never worked for me either but I just log in when I can.
markysimon
Ditto me... but after starting or when following-up a thread, especially one of some urgency (like currently, see Petrol Engines: De-Gassing Tank), it'd be good to know when someone replies with helpful suggestions!raynoon wrote:It's never worked for me either but I just log in when I can.
Cheers – Mark W
- djg
- Orga / RP numbers: 7903
Not that it'll necessarily help you but if you happen to use the forum from mobile via Tapatalk, it works there. You can receive both push notifications and emails, if you ask for them.
Bye,
Gábor
Gábor
Its apparently a host or server problem i beleve. Cairan has explained it to me before but i cant remember now.
We are ALL in the same boat . Tapatalk must use their own reply recived system
- djg
Yes, it does, it's a completely different mechanism.
Bye,
Gábor
Gábor
chris8189
- Orga / RP numbers: 7309
7548 - Location: Northumberland
Yeah, Tapatalk is definitey easier and more friendly to use when on this forum, or any forum that allows it to be honest.
Sent from my Signature Touch using Tapatalk
'98 'R' XM 2.0L SX Auto RP 7309
Notification of replies...
Presume you've tried setting
User Control Panel > Board Preferences > Edit Posting Defaults > Notify me...=Yes
plus e-mail address entered under Edit Profile - presume needed.
I think I used that some time ago, but eventually switched it to No.
