Series I Dashboard
citroeneer
Series I Dashboard
Just wondered, my mechanic mentioned that brand new Series I Dashboard is still available in the UK? Is that true? How much would it be?
From Malaysia...........http://www.flickr.com/photos/autojunk
Current : Citroen XM 2.0 (Series I 93')
Past : Citroen ZX 2.0 Volcane (94'), Fiat 131 Mirafiori, Proton MPI
- andmcit
Re: Series I Dashboard
I can imagine the cost from Citroen in the UK would be the equivalent of buying a whole secondhand Xm
here! (and have change!) I probably have a good used one - getting it to you may be a challenge mind
- it's very heavy!!
What's happened to yours!? Sun damage/splits?
Andrew
- it's very heavy!!
Andrew
citroeneer
Hi Andrew,
Well the dashboard is good except that its slightly split in the front area where the LCD panel, A/C controls reside. Not so noticeble though.
Good to hear that you have it, maybe will wait when I really need one.
Another issues is my sunroof which has failed. When the buttons are pressed, there's a noise of the motor moving but the sunroof doesnt move. The suspect would be the gears. Any ways to get that repaired?
More likly to be the cables...
paul
paul
DerekW
If it's the cables it means dropping the headlining. I've done it on a BX but never an XM, but I guarantee there's someone on here who has.
Derek
Derek
Hi Derek,DerekW wrote:If it's the cables it means dropping the headlining. I've done it on a BX but never an XM, but I guarantee there's someone on here who has.
Derek
These two threads (#ONE - #TWO)explains on how to do it with some good tips if your doing it single handed too !
