My headlining is coming adrift above the driver's sunvisor - at present, it is just slightly along the front edge that abuts the windscreen. Can I simply use pva glue to hold it back up or is there some more sophisticated glue that will hold it up - don't want it to get worse but don't want unsightly marks all along the top.
HELP!!!
headlining
messerschmitt owner
Re: headlining
I had a similar problem and used brush on impact adhesive quite successfully. Obviously you have got to be a bit careful when applying the glue, but it should be quite straightforward. With regards, Matthew T.
messerschmitt owner
Re: headlining
thanks
I will go try that and see what happens.
[/url]
