Door locks interchangeable?
Themasteryeti
- Orga / RP numbers: 1993 XM Break 2.1TD RP5958
Hey guys quick question, will the lock barrels from a later xm fit in the earlier models?
Re: Door locks interchangeable?
Yes, they are the same locks.
Themasteryeti
The ignition lock changed from Simplex to Bendix (Iirc) at Rp 6078 and the number of leads out of the switch also changed.
Simplex type has 1 grey + 2 black connectors
Bendix type has 1 grey + 1 black + 1 brown connector.
Afaik, physically the locks are the same, so with either changing the lock barrel, or switch, or a bit of wiring, one could make either work.
Themasteryeti
Thanks for the info! I take it the lock barrels is just held in with a torx bit it something so that it'd just pop out and go in the other?Dieselman wrote: ↑Wed Oct 01, 2025 6:29 amThe ignition lock changed from Simplex to Bendix (Iirc) at Rp 6078 and the number of leads out of the switch also changed.
Cut the ty-wrap binding the cables to the column, insert the key, turn to position 2 (iirc), depress the spring loaded pip and pull the barrel out.
Flegmaatikko
- Orga / RP numbers: 5082
May I ask why you want to change the door lock? Other option would be to modify the original locks to accept any sx9 key.
-90 XM V6 ERT
