Citroen Centenary celebration, Coombe Park
Re: Citroen Centenary celebration, Coombe Park
Post by Dieselman » Fri Jun 07, 2019 5:26 pm
MTXM wrote:
Fri Jun 07, 2019 3:34 pm
I think it is staying black Russ on account of the engine bay, although I think Will would prefer Mandarin! The restoration certainly looked impressive and apart from the paint there is just the engine to polish! With regards, Matthew T.
...and fit a distributor lower cover... Hint... ;)
Post by White Exec » Fri Jun 07, 2019 7:14 pm
On reflection, the colour scheme is pretty much 2CV Charleston...
Post by Dieselman » Fri Jun 07, 2019 7:22 pm
Will it be more economical with 4 injectors disconnected?
Post by Dieselman » Sat Jun 08, 2019 3:03 pm
onza100 wrote:
Wed Jun 05, 2019 9:06 am
Was good to chat to you Matthew.
If you do remember where you bought the ball for the gearbox linkage please let me know. I had a look online but haven't found anything suitable yet.
OT.
Would a bonnet/tailgate gas strut ball be the same size, alternatively any gearbox ball-joint, All linkage controlled XM gearboxes are either BE3 or ME5T, which I believe are all the same ball joints.
Alternatively...
http://www.springfixlinkages.com/en/cat ... tuds/r3526
or BMW bike part number 07119901736
onza100
Post by onza100 » Sun Jun 09, 2019 12:54 pm
OT.
Alternatively...
Thank you Dieselman. Funnily enough thats exactly what I've just bought.
The next problem is how to get it in there. Not exactly much room to get a drill in.
Post by MTXM » Sun Jun 09, 2019 2:10 pm
It was good to hear you have found a suitable part Paul and I seem to remember using a piece of broken off file to enlarge the existing hole on my 2.0i turbo! With regards, Matthew T.
Post by Dieselman » Sun Jun 09, 2019 2:29 pm
Theoretically, that lever unbolts from the selector shaft. Remove the inner wheel-arch liner to gain access.
That is the same ball that fell out on Vince's high mileage diesel on his way to Burghley house rally. A couple of tye- wraps saw him not only to the rally, but back home to Manchester.
That ball is a press fit /riveted union, so a dab of weld fixed it in place, but if the arm can't be removed, try a small carbide burr on a flexible drill drive, or remove the driveshaft.
You only need to remove enough of the splayed riveted end to remove the ball.
Tapping a thread and using a locknut should give a good and serviceable fix.
onza100
Post by onza100 » Mon Jun 17, 2019 8:54 am
Managed to fix it. Thanks for your help chaps.
I should really start a project thread for it.
