This thread may help
http://www.club-xm.co.uk/forum/viewtopi ... =13&t=1773
Buzzing Relay
hobblerian
Re: Buzzing Relay
Previous XM- 1990 H 2.1TD SD
Current XM- 1997 P 2.1TD VSX
harryjoe
Re: Buzzing Relay
AH HAAA !!
The suspect indicator stalk has now been stripped out, and a work out given ! cleaned up, it was in a bit of a state, removed all the crap, and NOW it's fine , no buzzing from th relay ! for the moment anyway, so all good
Just got to fit two new spheres in the fornt end ad it should be al ready for the CXM, got to give it a good once over with polish and it's all it top, apart from the hissing on tick over , which iv'e kinda got used to !!!
still got to fit the new rear o/s window motor 'n' cables which Frankin is supplying at the CXM, (toolbox in boot ready)!
'n' she'l be ready for me to put on the market once iv'e found a suitable diesel replacement.
I can't believe, iv'e got a Xm with no niggles !!
Saying that i will proberbly blow up on the way to the CXM
knowing my luck !!
1997 Xantia 1.8i auto (sold)
1995 Clio Auto 32k mint cond
1997 Xantia Estate 1.9 td
Re: Buzzing Relay
Nigel,harryjoe wrote:still got to fit the new rear o/s window motor 'n' cables which Frankin is supplying at the CXM, (toolbox in boot ready)!
Can I just confirm which side you need as on my breaking for spares topic you said:
Just so I know if I need to take out the other side or not.Hi Duke.
Does the rear n/s elecky window machanisam work the same for the estate as the hatch, my cables have shot themselves round in the motor, so in need the a replacement ???
Cheers.
harryjoe
Re: Buzzing Relay
Hi Franklin
Just to reply
It's the o/s rear
Thanks
Nigel
Just to reply
It's the o/s rear
Thanks
Nigel
