1991 Citroen XM V6 break renovation
TutajHamon
XM newbie
Post by TutajHamon » Fri Jun 19, 2026 7:18 pm
Hello everyone,
Recently I have become an XM owner after searching for my dreamed Y3 break with V6 and finally I managed to find one, unfortunetly it spend last 10 years or so grown into bushes so it requires some work. It's going to be quite a big project and as this is my first XM I decided to create this thread to share my journey threw renovation and ask for help to get it running and looking great again. This isn't my first hydropneumatic citroen as I own a 1987 BX 19 TRI also with break body (I love all the citroen break models).
With first post comes my first problem: the indicators are somehow always on but only on the side and back the front ones don't work at all. I thought about faulty switch or relay, so my question is how to get to indicators relay?
So this is all for my first post, I'll post another on soon.
Here are photos of my cars :mrgreen:
1991 Citroen XM Break V6
1987 Citroen BX Break 19TRI
Re: 1991 Citroen XM V6 break renovation
Post by Dieselman » Sat Jun 20, 2026 6:43 am
Your Xm appears to be in pretty good condition, well worth saving.
The front flashers not working is probably just corroded bulb holder connections, the flasher relay is mounted on the relay board, which is the back side of the fuse-board.
On a Lhd Xm, remove the left side dash panel and the fuse-board can be unclipped and hinged down to reveal the relays.
The flasher relay is #170. See relay board diagram in the Series 1 electrical diagrams thread. viewtopic.php?f=8&t=10268
It's possible the indicator stalk switch, or hazard switch might be shorting out due to damp, so check those. Is it possible this car has an alarm fitted, if so check that.
First thing to fix on an Xm is the parking brake, otherwise, on a non-running car, you have no brakes.
You hadn't said your Xm has no sunroof... 8-) Just noticed it has Romana velour seats, as well.
Those alloy wheels were designed for the Xm estate and suit it very well.
TutajHamon
XM newbie
Post by TutajHamon » Sat Jun 20, 2026 9:36 am
I'll go check the relays today and it appears that someone mounted some kind of aftermarket alarm because there is a falshing LED on the vent control. You have a pretty sharp eye there are in fact velour seats with electric control and there is no sunroof but I noticed that citroen estates don't get sunroofs in Bx and Cx I think it's mainly because of that height extension in the middle of the car but I don't know if it applies to Xm or not. And about the Xm condition there is rust but, as I deducted myself, it is there because of the poor quality body repair as the car probably hit some kind of barier on the right side but genius 00' Polish mechanics just put car putty on dents and it corroded but only the outside panels are in bad shape the structural parts still are still ogrinally galvanized.
Anyway I have some good news I managed to start the engine with help of a brake cleaner can because the fuel pump doesn't get any electricity. I think the leftover bits of an LPG installation can cause issues I'll investigate this more today.
Post by Dieselman » Sat Jun 20, 2026 9:53 am
The relays on the front of the ECU box are well known for causing electrical issues with the ECU and fuel pump power. The circuit diagrams are in the previously linked thread.
Also find the engine information in the Engine Management thread: yours is Fenix-3. viewtopic.php?f=13&t=10588
If the engine fires using an external fuel source then the crank sensor, Ecu and ignition amplifier are receiving power and are functioning properly.
The Gnd for the fuel pump is under the steering wheel, via(iirc) three connectors.
A Blink Code reader will be useful for reading any codes on your car. You can even perform tests using it.
Blink Code reader thread. viewtopic.php?f=8&t=7368
An aftermarket alarm could be interrupting the fuel pump signal and the LPG kit will switch the fuel pump over from petrol to gas.
Hopefully we should now see a video of your car driving this afternoon... ;) :)
p.s. UK Xm and Bx estates had sunroofs fitted either as standard, or optional. :evil:
TutajHamon
XM newbie
Post by TutajHamon » Sat Jun 20, 2026 8:29 pm
Unfortunetly car still won't start on its own but i managed to find the alarm module and the indicators started working normally. When I came to my Xm it randomally stopped cranking but after repairing the ground connection problem dissapeared. I have an idea to connect fuel pump to separate battery and run it independly just to start the engine also I checked relays next to the ecu and all seem to work just fine. Tomorrow I'll try starting the engine again.
Post by Dieselman » Sun Jun 21, 2026 7:13 am
Just use a test lamp to check for +12v from the relay and reliable Gnd.
The order of function for power to the pump is on Ign on the relay closes for 1s to prime the pump, then it closes once the crank sensor sees engine rotation.
We know your crank sensor works because the Ecu creates the spark.
Firstly, using the test lamp ensure you have the 1s, +12v pulse at Ign on.
The fuel system relay is item 807, which should have two thick Blue wires, a Green and a Brown one.
Blue/Black trace is Batt +ve.
Blue/Red trace is fuel pump feed
Green is Ign +ve.
Brown is Ecu switched Gnd.
If you temporarily short the two blue wires together the fuel pump should run. Don't leave it like this as the relay is a safety device.
After testing you have Ign +ve on the Green wire, you can test the relay functions by shunting the Brown wire to Gnd, with Ign on.
Due to having the LPG system installed, it's possible the power/Gnd to the injectors has been disabled, so check for those.
These injectors are batch fired so all fire together, twice per engine revolution. Injector +12v is supplied by relay 807 and Gnd by the Ecu.
Test using a test lamp and you can even have the Ecu perform a test by using a Blink Code reader. Only perform an injector test once, or twice if the fuel system has pressure, otherwise you could flood the cylinders with fuel and cause hydro-lock when cranking the engine.
This is a useful test for checking individual injectors.
Are you comfortable reading wiring diagrams and using a test lamp? If not call out for help.
Flegmaatikko
Orga / RP numbers: 5082
Post by Flegmaatikko » Fri Jul 24, 2026 6:07 am
Early XMs had non running and stalling issues that were caused by poor connection with two big connector under the LHM tank. I can’t remember what wire is the main cause, but usually wiggling both of them will fix the issue for a short period.
-90 XM V6 ERT
