Post
by White Exec » Tue Jan 19, 2016 5:20 pm
raynoon wrote:It's the pipe nut Chris, the one with the arrow pointing down. I don't know which seal it needs
This isn't helped by iPad and PC showing 90deg rotated photos!!
If the pipe nut (pipe looks to be either 4.5 or 6.35mm from service-citroen parts diags), then all you should need is a standard union sleeve-rubber of the right size. Citroen parts counter.
>>>Put this right someone, if not the case.
Post
by Dean » Tue Jan 19, 2016 5:35 pm
get your card out
raynoon
- Orga / RP numbers: 6043
Post
by raynoon » Tue Jan 19, 2016 6:29 pm
UPDATE: The water bowser.... Sorry I mean K-BAN is now out of the elements and is in the same hotel as KVG.
I've taken out the sunroof cassette, and brought it home, I'll have a go at doing something with it tomorrow with the hope of re-fitting it on Saturday. Even after removing the cassette the amount of water that was still inside is shocking, if you have a leaky sunroof you need to do something about it.
raynoon
Post
by raynoon » Tue Jan 19, 2016 6:39 pm
Ordered 2 of those seals as KVG was leaking from the same place too, many thanks Dean and Chris for your help.
Post
by Dieselman » Tue Jan 19, 2016 6:46 pm
raynoon wrote:Even after removing the cassette the amount of water that was still inside is shocking, if you have a leaky sunroof you need to do something about it.
Like welding in a new roof skin, without a sunroof...
raynoon
Post
by raynoon » Tue Jan 19, 2016 6:54 pm
YES! Exactly that! It'd be so much easier.
Post
by Dieselman » Tue Jan 19, 2016 7:28 pm
I've just been out o check the Cobalt car and with the headlining removed, other than a few spots of condensation on the sunroof glass, the car is now completely dry. I intended to investigate further today, but at 0 degrees c, it wasn't the day for doing that.
If this is unsuccessful, a new roof panel will be going on.
raynoon
Post
by raynoon » Tue Jan 19, 2016 8:11 pm
Dieselman wrote:I've just been out o check the Cobalt car and with the headlining removed, other than a few spots of condensation on the sunroof glass, the car is now completely dry. I intended to investigate further today, but at 0 degrees c, it wasn't the day for doing that.
What have you done with it?
raynoon
Post
by raynoon » Tue Jan 19, 2016 8:12 pm
And do you want to sell your spare cassette??
Post
by Dieselman » Tue Jan 19, 2016 10:48 pm
Removed the headlining to let it all dry out and to observe why the water isn't exiting the cassette, as planed.
