Tony's 1994 Xm prestige. 2.0 turbo.
Re: Tony's 1994 Xm prestige. 2.0 turbo.
Post by Dieselman » Mon Aug 12, 2013 5:18 pm
To get the scuttle end caps off I find it is best to lift the upper edge off first, then push down to unclip the bottom hooks.
spitroen
Post by spitroen » Mon Aug 12, 2013 6:00 pm
Got panel off. Tried to undo some strange looking bracket from round a rubber thingy. Hardy any room for spanner to move. Took a small nut of. No luck. Ain't got a fooking clue!!! No signs of any rubber hoses. Pic to follow.
Tony.
S1 Auto prestige 2.0 turbo petrol. RP 6064. Production date. 19/06/93.
Saab 9-5 HOT 2.3 Aero.
Post by Dieselman » Mon Aug 12, 2013 6:23 pm
Use a socket set, it's easy then.
Post by Vince » Mon Aug 12, 2013 6:57 pm
Hi Tony,
There are some pictures of the scuttle removal on page 40 of my page....Vince's xm fixer upper ;)
spitroen
Post by spitroen » Mon Aug 12, 2013 7:09 pm
We're do I get a replacement rubber button thingy from??
Tony.
Post by Dieselman » Mon Aug 12, 2013 7:10 pm
A Citroen dealer.
Post by citroenxm » Mon Aug 12, 2013 7:22 pm
(Hope this works correctly)
This might help you...
spitroen
Post by spitroen » Mon Aug 12, 2013 9:52 pm
How the hell do I get this rubber button out? And weres the return pipe?? All I can see is a rubber thing with a bracket around it. Duh??
Tony.
Post by Dieselman » Tue Aug 13, 2013 4:52 am
Undo the three torx bolts holding the black bracket done to the scuttle, it will then lift up.
Undo the two bolts into the brake valve then it will come away to reveal the hog ring holding the rubber button in place. (you can just see it in your picture, through the hole in the black bracket)
prop the valve up on a wooden block, or similar. Prise out the hog ring and pull out the rubber button, which judging by the wetness is indeed leaking.
Replace with new button, press in hog ring, rebuild bracket, ensuring when in position there is 9mm of free play.
10 minutes work all in from this point.
spitroen
Post by spitroen » Tue Aug 13, 2013 7:45 am
Thanks dieselman, will do this today.
Tony.
