Eddie nuff
Post
by Eddie nuff » Sun Feb 07, 2016 2:27 pm
One problem I encountered was when I was fitting the gear linkages in. I felt a few drops of water on my face, turns out they came from the pipe that runs into the bulkhead, the pipe with the bleed valve on it
The picture's not brilliant as it was quite dark by now.
The pipe from the engine to the valve is in good condition but it's not very solid in the valve holder and may need replacing. In fact it may be prudent to do so.
Post
by Dean » Sun Feb 07, 2016 5:24 pm
raynoon wrote:Thanks Neil! It's something I've wanted to do but thought I had to take the brake pipe out too
You don't indeed but you do need to get to the abs sensor and unplug it over the top of the subframe as its threaded through the shield.
Post
by MTXM » Sun Feb 07, 2016 6:01 pm
Looking good Neil and well done for all your hard graft!! She will be ready when show time starts. With regards, Matthew T.
Eddie nuff
Post
by Eddie nuff » Sun Feb 07, 2016 8:11 pm
That's the plan Matthew or, more to the point, the hope at least.
Sorry, forgot about this new fangled abs thing you have on these more modern cars.
Eddie nuff
Post
by Eddie nuff » Mon Feb 08, 2016 2:22 pm
Welding done
raynoon
- Orga / RP numbers: 6043
Post
by raynoon » Mon Feb 08, 2016 6:43 pm
Nice work!
Post
by Dean » Mon Feb 08, 2016 7:05 pm
It's looking very tidy, glad to see you tracked down the gear selector links in the end, that will make it much nicer to drive.
Post
by russ92xmsed » Mon Feb 08, 2016 8:10 pm
Smart job.
Post
by Dieselman » Tue Feb 09, 2016 3:17 pm
We will have to mark you down at show time though Neil. Those brake backing plates should be silver coloured, not black.
It's all looking rather tidy.
Post
by citroenxm » Tue Feb 09, 2016 6:55 pm
Wow neil, that must be the tidyest subframe and chassis area ive seen for a while.
My 24v is due another coat of underseal, though she is still all looking ok under there..
