Re: Russ's 2.1 SED Auto
Post by CitroJim » Sat Jun 01, 2013 3:15 pm
Has the 2.1 of Russ's vintage not got an ally sump then John?
And don't forget the gorillas used by garages to do up sump plugs :evil: They don't help. Sump plugs do not need to be done up to 350 ft lbs but try telling some garages that :evil:
Post by russ92xmsed » Sat Jun 01, 2013 4:28 pm
Thanks chaps for the info. I do believe it is an 8mm square holed plug. That does sound right. :)
Interesting about the tightness....I think it certianly is an alloy sump. I will be careful. Well because of not having the right tool, or having something that would do, I haven't really tried to loosen it, so no idea if it is stuck. It has a slight seep, so maybe it is free. If not, then I'll have to get it sucked out.
The last person to change the oil, is a well known Suffolk based specialist. ;) so no idea there how they change the oil.
Has anyone had a serious leak from their sump gasket, or had any horror stories of it going suddenly?
Rommel
Post by Rommel » Sat Jun 01, 2013 4:30 pm
Russ, mine is both, the 8mm square insert and the outer part 21mm hex. I presume as Jim says they are all/mostly like this.
I preferred using the 21mm outer part to unscrew, as it just felt safer and easier applying the loosening torque here than on the 8mm square insert. I didn't want to face the possbility of rounding it off. Much easier this way IMO.
You could get a new sump plug with the 21mm/8mm combo head. It's cheap and you'll be thankful you did.
Hey, 12 months MOT! :D Congrats!
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
Post by CitroJim » Sat Jun 01, 2013 4:37 pm
Get the right tool Russ, take it gently and it'll be fine, just don't go mad at it and use a long breaker bar gently rather than a short bar aggressively if it is really tight. That way you stand a lot less chance of inflicting damage..
russ92xmsed wrote: The last person to change the oil, is a well known Suffolk based specialist. ;) so no idea there how they change the oil.
They most likely get Harry Potter to cast a spell over it... Seriously, if they were the last to do it I'm sure they won't have done it up silly-tight...
russ92xmsed wrote:Has anyone had a serious leak from their sump gasket, or had any horror stories of it going suddenly?
Only on an ES9 Russ so you’re OK ;) Quite a common failing actually due to no gasket, just sealant...
Post by russ92xmsed » Sat Jun 01, 2013 4:49 pm
Mine has sealant. You can see it.
I think I might do as Rohan has suggested and get a new plug with the outside bit. Mine is flush fitting and only has the 8mm hex. Mind you it still means buying a new tool for this one to get it done. ERRR nothing is easy!! :lol:
I will do as I'm told Jim...nice and carefully...Don't want any creased up sumps. ;)
Thanks very much Rohan...yep it got through. :P Massive relief.
I like Johns advice on the emissions... just sit with it running until it goes in! Must do that next time.
Post by CitroJim » Sat Jun 01, 2013 4:58 pm
russ92xmsed wrote:Mine has sealant. You can see it.
That's not very professional :twisted:
Halfrauds do new sump plug and washer sets along with most decent factors. beware there's two sizes and I can never recall which fits what only that I know on my fleet I use both so I tend to buy one of each every time to be sure I get one that fits...
Post by russ92xmsed » Sat Jun 01, 2013 7:21 pm
Admittedly it isn't that much...it is the bits that squidged out when it was last done.
I'm of to Halfrauds tomorrow. 8mm square socket adapter oil drainage end thing is 5 quid. Hopefully more successfully tomorrow. :D
Post by robert_e_smart » Sat Jun 01, 2013 8:30 pm
The XM sump washer goes nicely over my little finger! The smaller one is for the more modern stuff!
Post by Dieselman » Sun Jun 02, 2013 2:17 pm
Grind an allen key down to make the 8mm square tool, then knock the end of the sump plug with a hammer, insert the tool and knock it round with the hammer.
Shock is much better for undoing tight threads than axial force.
Post by russ92xmsed » Sun Jun 02, 2013 6:31 pm
Well that's one way of doing it. :lol:
I prefer going to Halfrauds and being told by their demented computer system that the key bit I needed was in stock but only available to collect on Tuesday...I now officially hate Halfords! :evil:
Went to the Gloucester branch instead. It is so much better. Like old Halfords used to be. And there it was...with a golden halo around it!!!
So tomorrow I will complete this simple task of changing the oil.
