dollywobbler
Post by dollywobbler » Mon Aug 17, 2015 12:12 pm
It's not sand, just off-cuts from fence posts. Probably 400kg plus trailer. And the blue sky has gone now. :(
However, it is handy being able to raise the car's suspension, to reduce the ramp angle. One bag emptied out so far.
1986 2CV6 Dolly, 1980 Dyane
Post by Dieselman » Mon Aug 17, 2015 12:24 pm
I suspect it is the low pressure spheres causing the ride to change. An XM should tow well.
dollywobbler
Post by dollywobbler » Mon Aug 17, 2015 2:10 pm
Aye. I'm minded to agree. Though I've had a similar effect in non-hydractive Citroens when towing before. I'm pretty sure my immovable centre sphere is weak though.
mds141
Orga / RP numbers: 8542
Post by mds141 » Mon Aug 17, 2015 9:01 pm
I've found the ride quality to improve slightly whilst towing the caravan. Plus it gives the rear brakes a good workout.
Mark Smith.
1997 Honda Firestorm.
Post by White Exec » Tue Aug 18, 2015 6:00 am
mds141 wrote:I've found the ride quality to improve slightly whilst towing the caravan. Plus it gives the rear brakes a good workout.
Interesting observation, Mark.
Where the XM has significant weight over the front wheels (particularly in the case of the diesels), the back end is fairly lightweight in comparison. The suspension is at its best when it's acting against considerable weight or inertia, particularly in the later versions of the fluid suspension. Caravan towing, or just a couple of rear seat passengers, can bring out the best in the ride.
Probably why XM back end ride is so nasty when the (rear) centre sphere isn't doing its stuff, all the more so with an empty car.
The ride in a hydraupneumatically suspended Rolls Royce must have been quite sublime.
dollywobbler
Post by dollywobbler » Tue Aug 18, 2015 7:36 am
Don't forget that the Roller always used coil springs, conventional shockers AND spheres. Really, the spheres were there purely for self-levelling. The ride is pretty darned sublime though.
I guess I'm going to have to find a way to get this sodding centre sphere changed.
Post by White Exec » Tue Aug 18, 2015 7:56 am
It just has to unscrew.
I know you've done it before, but
- relieve fluid pressure (by every means available)
- get a stillson or something on the sphere holder to prevent twisting
- clout sphere as per expert advice
- use sphere removal tool, with extension tube if nec., and heave
Well, that's how I'd try it!
Post by Dieselman » Tue Aug 18, 2015 9:06 am
I had to chisel a centre rear sphere off as it really was bound on tightly.
Post by xmexclusive » Tue Aug 18, 2015 10:14 am
The bolt fixings into the rear axle tube are just spring clips.
They are easily damaged and give.
The 10mm main feed pipes are no longer available.
I would be inclined to get a spare base and fit that with the new sphere.
The remove the old one with the base in a big vice.
Post by White Exec » Tue Aug 18, 2015 12:28 pm
Just as an afterthought, if there's any doubt whether system pressure has/has not been relieved (if it hasn't, getting the sphere unscrewed will be nigh on impossible), there is a drastic course of action available...
- remove sphere top plug, so releasing any gas
- spear the diaphragm with a suitable spike - and be prepared for an outrush of fluid
That will knock the pressure off.
