1 - LHM fluid level: You are checking it correctly (Highest, gold disc should be between the two red lines), but the simple float mechanism has been known to get stuck. Easily removed and freed up. At correct level, fluid surface should be about 12cm from the top of the tank filler neck. Over-filling by 1-litre+ not a problem; under-filling can result in air getting into the system.
2 - Quite common if car has been stood overnight, or is asked to go to Highest at idle speed. If the warning doesn't come on otherwise, then everything is OK. On a start-up after overnight standing, if the warning/Stop is on for more than 10 secs or so (car left at Normal height), then it is a sign that system would benefit from a flushing: see posts here about Hydraurincage.
4 - Stuttery rise and clunk from rear. What you would expect from a slightly lazy hydraulic system. Struts do get a bit arthritic with age. Regular use and Citrobics will help, as will flushing and new fluid and reservoir filters (if very dirty).
6 - Height lever can be pretty stiff. Check underneath the car, that the control rod is lubricated where it passes through the several supports, which clag up. Oil/grease.
7 - Buzz from sunroof area is the tiny fan ventilating the internal temperature sensor. Drop the light fitting (lens pops out first) and you'll find it. Defluff and WD40/very light oil.
Common fault; lubrication usually leaves them silently working.
Nice clear pix!
Had a friend who would list the things that would persuade him to buy a secondhand car:
1. MoT, 2: decent tyres, 3: Any money behind the back seat.
