The ever evasive window regulator...
JohnCowperPowys
- XM newbie
I'm trying to track down a window regulator (drivers door) for a es9 v6 year 2000. Will swap for a pink unicorn. Bosch number 0 130 821 688. Any ideas?
Re: The ever evasive window regulator...
They are not impossible to find.
Be aware that there are at least two different versions.
Citroen changed the wiring plug in 1996.
What is wrong with yours?
Broken drive wire or non working electrics?
I think I mentioned this over on Facebook. Was you I told I might have a unit from a W reg. And said there was a change in them.. I'll still need to find the said regulator though..
