Hi.
Welcome to winter! The weather has reminded me that I need a new black leather rear seat bench, for an S2 and it's got to be heated! Unfortunately mine has quite a nasty rip in the seat base that could be mended, but if someone wants to sell me a good condition heated replacement, then that would be even better!
I also need most of the plastic front and grill off the front of a silver year 2000 car. The placement and size of the chevrons changed on the year 2000 model (well about then). I must be getting lazy in my old age because mending this is really a summer project!
Cheers
Stephen
Wanted: S2 Leather Heated Rear Seat Bench and front grill
SteveLP
Re: Wanted: S2 Leather Heated Rear Seat Bench and front gril
Hi stephen..
I might be able to find a heated base.. ive two candidates that might still work...
Cant help with a grill. Ive only S1 grills... ive got an s2 grill but in green. Was hanging onto it for now..
I have a brand new, unpainted, S2 grille.
Two versions of the Mk2 grille, late ones had larger size chevrons.
Chevron section unbolts from main grille, has the existing centre section survived?
SteveLP
I didn't know that the Chevron section came apart. Ideally I'd like that bit as well as I've lost one of the metal chevrons and I think they are bigger (I'll have to check at the weekend). But I'm interested in having an unpainted part and getting it sprayed in the right colour. Thanks!
Back seat would be great too. I'll pm you both. - I think that the seats didn't change between S1 and S2 hatchback although I'm sure John knows!
Will pm you both!
Thanks
Steve
Will pm you both!
Thanks
Steve
Heated rear bench seat common to both Mk1 & Mk2 even the electrical plugs are the same.
