XM aftermarket wheels
hank123
Post by hank123 » Wed May 24, 2017 11:15 pm
Hi, can anyone advise on this subject please. Regards hank123
tich731
Orga / RP numbers: Orga 8072
Re: XM aftermarket wheels
Post by tich731 » Thu May 25, 2017 7:49 pm
Don't do it.
Original equipment wheels can't be beaten, in my opinion.
1999 2.0L TCT VSX Auto Balmoral Blue
Onion Johnny
Orga / RP numbers: RP7302 Silver 01/1997 Series 2 Hatchback. 2.0 TCT
Post by Onion Johnny » Tue Jun 13, 2017 9:54 pm
I got a set free with a car I scrapped. They are OZ, unusual six spoke and look very cool in a sort of conservative way. Slightly wider but the 205 60 tyres fit fine. Don't buy any without the bolts as original bolts fit only Citroen wheels. Don't forget if you buy 4 you'll need a spare so will have to carry a wheel set of originals to fit the spare.
You need to measure the offset too as rear arch space is not huge. The original wheels have my winter tyres on and the OZ my summer pirellis so works well when time comes to change.
hank123
Post by hank123 » Tue Jun 20, 2017 7:52 am
Hi Johnny, many thanks for your advice. I have been told Volvo 850 T5 wheels fit ok?. hank. PS, do you have the OZ still
Post by Dean » Tue Jun 20, 2017 4:35 pm
Hi Hank
Almost all Volvo wheels do fit fine and look pretty good as there is a wide range of styles that work well with the XM shape, I recently tried a T5-R Pegasus 5 spoke on my XM but it was 18" and was super tight in the rear arch, ants would get crushed in the tyre to arch clearance and I suspect in use you would need to fold the rear arch lip over to make it work but stick to the 16 and 17" and you wont have any issues.
hank123
Post by hank123 » Fri Jun 23, 2017 7:27 pm
Hi D, I was thinking about trying Volvo wheels, but none had the correct offset-ET or width. Which ones would you advise? I'd like 16" x 6.5 five spoke. Any advice would be most welcome. hank
Jan-hendrik
Post by Jan-hendrik » Sat Jun 24, 2017 8:57 am
These Volvo rims fit perfectly and use the original XM wheel bolts. I got these 15 inch rims thrown in for free with the (used) winter tyres some years ago. Sold them on later to a Volvo owner after I got myself sets of XM rims :)
16 inch rims may look interesting, but I still tend to think the XM rides best on original spec wheels and tyres.
Post by Dieselman » Sat Jun 24, 2017 9:09 am
Are the centre spigots the same size on Volvo wheels asn Citroen wheels? If not the load is being carried on the wheel bolts, not the spigot.
Post by Dean » Sat Jun 24, 2017 10:51 am
Im not sure but they fit so are either the right size or too big, all you have to do is buy the nylon hub spacer rings, its the same thing I have for my alloys and that allows the weight to be carried in the hub flange but more importantly the wheel to mount correctly and center to the hub.
Jan-hendrik
Post by Jan-hendrik » Sat Jun 24, 2017 11:14 am
Yes, they are.
