Selling off one (or bits
markysimon
Post
by markysimon » Mon Apr 17, 2017 6:15 pm
As it looks like I'm
finally going to repair my ailing LH digi-display (see other thread), I'll to have to remove the dashboard, and so I might as well try and replace the entire padded fascia that surrounds it which was damage by vandals who broke into the car (S2, 3-litre Exclusive) three years ago. (The vinyl to the right of the dash, near the ignition barrel, was quite badly scarred). So does anyone have a replacement or knows where I could buy one?
And whilst I'm at it, the rubber gearlever handle was badly cut and also could do with replacing.
Cheers – Mark W
1997 V6 24valve Exclusive
1995 XM VSX Turbo (Deceased)
CitroRS
Post
by CitroRS » Mon Apr 17, 2017 7:32 pm
If gear lever is same as on Peugeot 605, take a look at my topic -
viewtopic.php?f=11&t=7642&start=70" onclick="window.open(this.href);return false;, I found 605 3.0 graveyard, maybe you could find something that will fit.
Post
by Dean » Mon Apr 17, 2017 7:37 pm
dont forget you will need a RHD gear lever, LHD wont fit. They were still available from citroen 3 years ago but again, make shure they order a RHD one.
I may have the parts you want for the dash, possibly, but i will need to check next weekend.
Post
by xmexclusive » Mon Apr 17, 2017 8:12 pm
Is the Mk 2 dash with passenger air bag identical to the one without?
Post
by citroenxm » Mon Apr 17, 2017 8:55 pm
I think the dash mould is the same but has an extra bracket for mounting the airbag with a smaller glove box behind it.. the orface they fit in are the same size for a full size glove box.
markysimon
Post
by markysimon » Tue Apr 18, 2017 8:45 am
Thanks for the info and yes, my fascia is avec airbag.
Cheers – Mark W
Post
by xmexclusive » Tue Apr 18, 2017 9:18 am
The point I was trying to check was about interchangability.
I found it impossible to remove a passenger airbag from the dash shell insitu.
All the screws come from behind.
In my case I just cut the shell as I had no need of it at the time.
The cut out airbag and shell surround is somewhere in the heap as I intended to take some record photos of the fixing type and positions.
Old dash stripped out and new one going in is not the time to find that mods are needed to make the airbag fit.
In these later cars Citroen had integrated the airbag systems so leaving one out or unplugged will be a problem.
Some while ago out of interest I repaired the plastic top of an auto gear lever.
That must still be around somewhere in one of the heaps.
Will see if I can find that and see how reasonable it looks.
Post
by MTXM » Tue Apr 18, 2017 12:00 pm
Please note that the auto gear lever matches the ZX and was still available a couple of years ago through main dealers. Regards, Matthew T.
Jan-hendrik
Post
by Jan-hendrik » Tue Apr 18, 2017 12:43 pm
Deleted.
Jan-hendrik on Tue Apr 18, 2017 12:46 pm, edited 1 time in total.
Jan-hendrik
Post
by Jan-hendrik » Tue Apr 18, 2017 12:45 pm
Matches Xsara and Xantia as well.
Jan-hendrik on Wed Jun 07, 2017 7:14 am, edited 1 time in total.
