Didital aircon panel
XMV6 sadist
Post by XMV6 sadist » Fri May 01, 2009 9:40 am
Hi
It looks like the digital aircon panel in my XM has given up the ghost (fans are stuck on). Anyone got a spare one for sale?
Or maybe thoughts if you don't think it's the aircon panel.
Cheers
Tony
onthecut
Re: Didital aircon panel
Post by onthecut » Fri May 01, 2009 10:23 am
Hi Tony.
Not my scene, electrics, but surely the control panel itself doesn't handle the full fan current, in which case, might it be a stuck relay further down the line ---- or a temperature sensor gone, so the sytem is trying to work to achieve a fictional result ? If it is the panel, someone has had one on Ebay recently -- don't know if it's still on.
Mike.
Post by xmexclusive » Fri May 01, 2009 2:16 pm
Hi Tony
Pleased to see you have found out where we were hiding. The A/C panel on ebay was by a seller in Chesterfield breaking a Maroon/tan trim 2.5TD exclusive. Still think he has some bits up now, will check and post the details. He wanted a extortionate £50 plus p&p for the panel. If you have still not got one in a week or so then I will be back home and can look out a working spare. Not keen on selling but it might be worth trying a panel swap with one of my cars. If the fault stays put at least you would know to look elsewhere for the fault.
Ken Newbold
Post by Ken Newbold » Fri May 01, 2009 3:15 pm
Is it for an S1 or S2 car?
XMV6 sadist
Post by XMV6 sadist » Fri May 01, 2009 3:17 pm
Hi John
Everything disappeared from the old list but I found where you were hiding! I agree with Mike that it could probably be a relay however the control panel has always had a mind of it's own in our car. Hence I'd like to take up your offer John to have a loan panel to see if this helps to locate the fault.
Cheers
Tony
XMV6 sadist
Post by XMV6 sadist » Fri May 01, 2009 3:18 pm
Hi Ken
S2
AlanN
Location: Wirral (N West England-across the Mersey from Liverpool)
Post by AlanN » Fri May 01, 2009 5:20 pm
Hi all-I found you too-with a little help from a friend! I emails the ebay seller in Chesterfield and got no response-my digital display has a mind of its own too and I thought a replacement might be in order.
Good luck with tracking down your fault or replacement .
Alan.
1995 XM 2.1TD auto Exclusive
1999 Xantia HDi Exclusive
Post by Dean » Fri May 01, 2009 6:07 pm
Hi Gents
Always worth having a check of the cabin temp sensor in the roof console for fluff buildup/functionality, if its duff it will make the fan go mental but will give either hot or cold air constantly on auto setting as it tries to counter the false reading, switching to manual would overide this though.
Post by xmexclusive » Fri May 01, 2009 10:26 pm
Hi All
Just to say that it is only the plastic trim shell that is different between the Mk1 and Mk2 versions of these aircon panels. The internal electronics and connecting sockets are identical so you can use a Mk1 one to check out functionality in a Mk2 car. Just have to leave it hanging loose on the wiring. I seem to remember that you can even swop the outer shells.
normantilbury
Post by normantilbury » Sat May 02, 2009 7:05 am
Hi, Having just gone through the same thing myself see my thread http://www.club-xm.co.uk/forum/viewtopic.php?f=8&t=49 it might help. you could try disconnecting the digital panel all it does is tell the bitron box to turn both fans on full speed. the bitron box or (temp control module) on mine is located above the accelerator pedal and held in place with 1 screw and a rather strange quick release catch.
Regards.
Norman
