1996 2.5TD Exclusive hatch, spares or repair, £250 Stoke
lankytim
Post by lankytim » Sun Jul 17, 2016 9:13 pm
Hi all.
I can't find my old XM sale thread, but since then I've managed to feck up my XM and I've pretty much taken the hump and decided to get rid again.
It's a big blue 2.5TD XM with 216k on the clock, most panels have dents, lacquer is crazed on the roof but it's got 5 months MOT (or so) and is the nicest car to drive i've owned. The half leather interior is nice, Volvo V90 alloys recent new tyres on the front, good part worns on the back, new front spheres, drop links, strut tops, timing belt and balance shaft belt (done 2 months ago!!) aircon rad and air dryer replaced (needs gassing up) coolant rad replaced (along with the little chargecooler rad) front brakes, rear pads. plus absolutely lots of other bits of work that have been done that I can't think of right now.
For the last MOT the rear axle was re-piped at a cost of £500 (owch)
The big issue with it is the N/S/R suspension ram needed to be removed to replace the ram boot, which was leaking. All went swimmingly until I had to reassemble everything. For some reason the high pressure feed union won't screw into the body of the ram far enough and it's leaking LHM fluid. It was mega tight when I undid it so I think there may be some corrosion that has borked the threads or something. I got annoyed and was hanging off the union with a pair of mole grips and a scaffold tube so it's pretty much fecked now. If you were to replace the ram and that section of pipe then it would be an easy fix, although I think the subframe needs to be lowered a little to get to the other end of the pipe. To be fair, it's easily fixable if you have the bits and more patience than me. The suspension all works, it's just there's a steady stream of LHM coming out.
Also, when I was under the back end I found a 50p sized hole in the rear chassis. No biggie, but it did nothing for my mood.
Apart from the aforementioned rust hole in the rear chassis the rest is very good. It had a patch on the sill for the last MOT, and the MOT before that had the front subframe patched. All done to a good standard.
As far as XMs go this is a good one, Body is good rust-wise, the dreaded cam belts have been done, awkward rads replaced, unobtanium strut tops replaced but the wife is on the verge of divorcing me with the amount of time I spend working on it, the kids think i'm dead/in prison so it really has to go this time.
Is £250 too much to ask? A bit of work and it'll be good to go. Plus is absolutely LOVES veg oil.
WILL NEED RECOVERING.
Needs a clean now, but here's some pics.
Pshemsky
Re: 1996 2.5TD Exclusive hatch, spares or repair, £250 Stoke
Post by Pshemsky » Mon Jul 18, 2016 5:14 pm
PM sent Tim
Prem
XM 3.0 Exclusive (2000)
Gone with the wind...
Xantia 2.0 HDI (1999)
C5 2.0 HDI (2003)
XM 2.5 TD (1996)
Xantia 2.0 HDI (2000)
lankytim
Post by lankytim » Fri Jul 22, 2016 8:39 am
Still here....
robby
Orga / RP numbers: xm 2.5td exclusive, rp 7085, dark blue (ugliest color :) ), LHD
Post by robby » Thu Jul 28, 2016 6:45 am
Hey lankytim,
I saw that you had new radiator for 2.5td, since you are selling it for spares is this new radiator available, and/or where did you managed to source new one?
cheers
robby
Robert
1996 XM 2.5TD Exclusive, LHD, RP 7085 dark and ugly blue
Keith10
Orga / RP numbers: XM 2.1 TD auto hatchback RP is 6045
Post by Keith10 » Sun Aug 14, 2016 12:39 am
Hi Robby
We all have a wife like yours who gets fed up of the time one spends on a cherished car. That said do you still have it I would be interested.
Keith
campaigner
Post by campaigner » Sun Aug 21, 2016 10:03 pm
Evening all :) this car went to it's new home last Sunday (14th August) made the 80 mile journey without a hitch, on arrival in Wakefield it decided to start leaking from the rear n/s cylinder, a problem described above. However 2 hours later with a new cylinder fitted, all's well. :D
It seems poor Tim had cross threaded the cylinder feed pipe because he's been unable to undo the pesky pipe clamp above the arm.
Post by Dieselman » Mon Aug 22, 2016 5:06 pm
Good result.
A helicoil may make that ram usable again as the fluid seat is below the thread section.
