Wanted- Philips Head Unit with code for MK2 XM
Rommel
Post by Rommel » Wed Jul 09, 2014 12:42 pm
As title....picture to follow. Anyone?
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
Re: Wanted- Philips Head Unit with code for MK2 XM
Post by XMX » Wed Jul 09, 2014 4:57 pm
Hi Rohan,
Has your unit failed or maybe missing the O/E unit/fitment ?
I may be able to help out, but IIRC correctly the display bulb/s are possibly burnt out on the head/units I have (But I will have the codes) !
I'll try and check my spares stock out tonight/tomorrow and report back !
kingp
Post by kingp » Thu Jul 10, 2014 9:11 am
I have one with burnt out bulbs as well if you wan one.
Though to be far a decent aftermarket unit slots and connects straight in and adapters are cheap enough for the wheel buttons.
djg
Orga / RP numbers: 7903
Post by djg » Thu Jul 10, 2014 9:52 am
But doesn't look half as nice as they original... [emoji1]
Besides, if you happen to have the LHD display that can display radio messages as well, you won't get that with any aftermarket or new unit.
Bye,
Gábor
Rommel
Post by Rommel » Thu Jul 10, 2014 10:05 am
Problem with mine is that the display seems damaged- it's still bright enough but there's no visible symbols anymore. And when you need to input the code...it just doesn't work!
I take it these ones being offered are still legible despite the blown bulbs?
Rohan
ES9 V6
Previous:
2.5TD VSX Estate
kingp
Post by kingp » Thu Jul 10, 2014 10:16 am
Mine is, just a pain to see but if you are ok to take bits off you could make one good one :)
Post by Dieselman » Thu Jul 10, 2014 8:45 pm
Rommel wrote:Problem with mine is that the display seems damaged- it's still bright enough but there's no visible symbols anymore. And when you need to input the code...it just doesn't work!
The display being blank means it needs the code. Do the buttons work?
Rommel
Post by Rommel » Sun Jul 13, 2014 2:01 pm
I can't tell, there are no beeps when I try and enter the code "blind". I think I somehow damaged the display when removing the unit as it was ok before. I removed it to get the product info so that I could get the code- I lost it somehow!
Rohan
ES9 V6
Previous:
2.5TD VSX Estate
