CITROEN 2.1TD XM spares injection pump Diesel 1992 Item number: 260470153070
He says it is leaking from the front bearing, does anyone know if a seal can be fitted without dismantling the pump? The bearing looks as though it has been pressed in from the outside. I have asked him if its been used on vegi oil.
I might have a go at it if no one else wants it.
Bosch pump on ebay
Bosch pump on ebay
jonathan_dyane
Re: Bosch pump on ebay
I *believe* (although I haven't replaced the seal on a Bosch yet) that you can replace the seal without dismantling... Have you got the Bosch VE technical guide? If not, PM me your email address and I'll send you a copy.
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
1986 MZ ETZ 250
Hi Jonathan
I believe I have now I come to think of it, I have something technical anyway, I will let you know if not, thanks
Its been used for veggie oil
- colinxm
Hi Peter, looking at my spare pump it looks as if it shouldn't be much of a problem to replace the seal without dissmantling, drill a couple of 1mm -2mm holes opposite each other into the face of the seal, screw in a couple of self tappers and then pull out the seal with pliers, there's quite possible a seating face behind the seal in which case the self tappers when being screwed in will push out the seal anyway if you "see" what I mean. The new seal should easily drift into place.
Running the pump on bio diesel only destroys the seals doesn't it ? shouldn't be any mechanical damage should there or doesn't bio fuel lubricate enough ?
Regards Colin.P
Regards Colin.P
1995 Cit XM 2,1 TD Silver Estate - deceased
2004 Opel Vectra Estate
2008 Kia Ceed td
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
2008 Kia Ceed td
1998 Ford Puma
1979 Triumph TR7
Thanks Colin
Sounds feasable, are there any other seals its likely to effect? Not heard of mechanical damage, I would think its oily enough.
- colinxm
Hi Peter, I haven't actually taken mine apart yet to know but I do know of the "O" rings on either side of the pump at the bottom for the timing advance mechanism cover plates and there are also two small diameter ones that go onto the max fueling screw. Obviously these are easy to replace with the pump off the car.
Best wishes Colin.P
Best wishes Colin.P
2008 Kia Ceed td
1998 Ford Puma
1979 Triumph TR7
2008 Kia Ceed td
1998 Ford Puma
1979 Triumph TR7
