Wanted: XM Cruise ECU
Post by CitroJim » Thu Apr 25, 2013 3:51 pm
Anyone got one please? The Hella part number is 5GA 004 397-17. I know a Xantia S1 one is the same as well but not the Xantia S2. How bizarre...
Full story of why I need one in my ES9 Topic in the members cars...
TIA :-D
Re: Wanted: XM Cruise ECU
Post by robert_e_smart » Thu Apr 25, 2013 5:16 pm
Will have a look Jim. I have a Hella ECU from a 2.1 TD.
Post by CitroJim » Thu Apr 25, 2013 5:22 pm
Thanks Robert, that should be perfect :D
zaphod
Post by zaphod » Wed May 01, 2013 11:06 am
I also have one from a 2.1! in fact the whole system except the pump
1992 Range Rover Vogue SE
1985 Golf GTI
1975 MG Midget
1959 Austin Healey Sprite Mk1
Post by CitroJim » Wed May 01, 2013 1:23 pm
Gentlemen, happily I no longer require one. I've fixed mine by the replacement of the three duff transistors and one duff zener I found... Now working a treat :D
Post by Dieselman » Wed May 01, 2013 6:27 pm
Nice fix Jim, now can you fix my radio?
robertmnorton
Post by robertmnorton » Wed May 01, 2013 6:42 pm
Hi Jim, good fix. Have you considered the cause of the failure ? Old age or an external component, ie pump ?
robertm
Post by CitroJim » Thu May 02, 2013 4:51 am
robertmnorton wrote:Have you considered the cause of the failure ? Old age or an external component, ie pump ?
robertm
I have Robert and came to the conclusion that it may have been used on a Xantia. It's an oddity that the Xantia S2 cruise ECU is slightly differently wired in that the vacuum pump motor control and the vacuum control electrovalve are wired opposite; the pump is on pin 7 on the XM and Pin 6 in the Xantia whilst the vacuum electrovalve is on pin 6 on the XM and 7 on the Xantia.
The pump takes a highish current and is driven by a BD535 power transistor. The vacuum electrovalve is a low current device and is therefore driven by a pair of little BC337 transistors. these were short-circuit, as was the 24v zener across the pump supply. the BD535 was tested OK but I swapped it as a precaution.
So, I think the vacuum electrovalve circuit tried to drive the pump and that took out the BC337s and the pump circuit trying to drive the vacuum electrovalve caused a big enough spike of back-emf from it to pop the zener...
So the moral of this tale is if you think an S2 Xantia has a duff cruise ECU don't try substituting an XM one. A quirk is that an S1 Xantia uses the same cruise ECU as the XM :? :roll: I can't explain that one either!
robertmnorton
Post by robertmnorton » Thu May 02, 2013 7:21 pm
Hi Jim, many thanks for info, I suspected the high current for the pump was key but thought mechanical issues with the pump the likely cause. Would never have considered a foreign unit (xantia) anyway.
robertm
Post by CitroJim » Fri May 03, 2013 5:00 am
It's bizarre Robert but every model that uses the Hella cruise have much the same ECU but the connector pin-outs are different in every case. I've got hold of some hand-drawn circuits of the ECU used an a VW Passat. It's very, very similar to the XM one but all the pins are different.
I guess the microprocessor program is slightly different for every model of car and this is a way of ensuring they can't be swapped between cars with potentially dangerous results..
