S1 Clarion radio
S1 Clarion radio
Does anyone have a fully working Series1 Clarion radio. I have two but both have problems.
Re: S1 Clarion radio
Which Sort Will, the First type, or the later RDS With CD Changer black front type??
messerschmitt owner
WIll
I have one from the blue XM I scrapped - it has the cd changer socket. AFAIK it is in full working order - can check it though!
Hi Guys,
The early grey type is what I'm after.
Also does anyone have the correct booklet showing the connections, as I might try to pass an mp3 player into the CD inputs.
messerschmitt owner
Will the one I have is black! So I'm out
Theres no cd input on the early grey clarion units... cd only came with the rds black fronted units... early units didnt even have rds they were pretty crap feature wise really..
Messerschmit owner have you got the code.. how much do you want for it???
messerschmitt owner
I have the code - let me pop it in the slot in one of the other XMs to test it works first. It worked in the XM it was in so see no reason why it won't work now. I could get it to Chester at the end of the month for onward collection. The steering wheel cable should be there too and manual.
£10 if it works delivered to Chester area or plus p+p
[/url]
