Manual gear knob
Manual gear knob
Post by Dieselman » Sun May 22, 2011 7:51 pm
As stated, I need a gear knob for a manual car as mine is split.
also, how do you remove the knob?
Re: Manual gear knob
Post by robert_e_smart » Sun May 22, 2011 8:12 pm
You just pull them off.
boyse7en
Post by boyse7en » Fri May 27, 2011 10:07 am
MIne's got three allen-headed grub screws holding it on. 3mm key from memory.
You just wriggle down the collar at the top of the leather gaiter to expose them.
1999 Alfa Romeo 166 V6
1977 Triumph Stag 3.0 V8
1984 Tiger Cat E1 2.1
1977 Austin Mini 1380cc
2000 Ducati Monster M600
2006 BMW F800S
Post by Dieselman » Fri May 27, 2011 6:13 pm
I've tried pulling the knob up, I've tried pushing the plastic collar down...no joy...Help.!
Post by xmexclusive » Fri May 27, 2011 7:58 pm
The leather pulls down out of the plastic collar.
Post by robert_e_smart » Fri May 27, 2011 9:37 pm
Twist and pull Will.
They are on tight. Only the automatic gear selectors are screwed on.
Post by Dieselman » Sun May 29, 2011 3:49 pm
On tight...Not half...but it did indeed pull off, so now I need a replacement.
The good news is that the car is now welded, just needs sealing and undersealing, then fit wipers, tyres and see if I can insure and take it for MOT without a V5 being available yet.
endorfin
Post by endorfin » Tue May 31, 2011 2:24 am
I think I have a spare XM gear knob, its a wood type one off a VSX though? Where are you located?
