It's a two bolt vented thermostat housing with a raised flange on the underside of 53mm and fits into the 54mm dia' thermostat body.
Thank you in anticipation.
Tim.
WANTED: 1990 2.0i 8v XM Thermostat Housing. OEM 1336 G0
Tim Young
- XM newbie
- Orga / RP numbers: 2.0 XM Si Auto 1990 (Saloon) RP4960 Paint Code ERH Vert Amandier
2.5Tdi Est 1997 Silver. Replaced with a 2.5Tdi Est in maroon from Savoy garage and was written off there undergoing titivation. Approx' 2022. - Location: LE2 3FF Leicester
Re: WANTED: 1990 2.0i 8v XM Thermostat Housing. OEM 1336 G0
Will the later 1336.A1 fit?
If not try alternate part numbers:
AKRON-MALÒ 116074
BIRTH 8445
CAUTEX 952110
CITROËN/PEUGEOT 133640 1336G0
DS 133640 1336G0
FARE SA 22028
METALCAUCHO 30617
STC T430617
TRICLO 461041
AKRON-MALÒ 116074
BIRTH 8445
CAUTEX 952110
DS 133640 1336G0
FARE SA 22028
METALCAUCHO 30617
STC T430617
TRICLO 461041
Tim Young
- XM newbie
Thanks Will,
the later 1336 A1 flange is too big at 56mm dia'. I searched the rest of the part numbers but any of the housings that would be suitable relate to 1336 A1 housing. The exact size of the original flange is 53mm and fits into the 54mm dia' thermostat body.
I've found one thro' qkcitroenclassics.com based in Poland and listed on the sales and wants as XM parts
by Southerneruk. I contacted them via WhatsApp and response was immediate. They are supplying one for 20GBP inc' postage.
I'll update when it arrives.
Thanks for all your time and help.
Tim
Tim
