wanted left wheel-house splash panel and rear washer jet.
Post by Dieselman » Sun Dec 21, 2025 7:29 pm
Left side front wheel-house splash panel and estate rear washer jet required.
The splash panel is the square one that protects the end of the gearbox from road debris.
Other nice to have items would be a Rhd front wiper motor, h2, or h3 Hydractive-1 Ecu, series 1 rotary dial automatic heating, heater control
Manual gear-knob and gaiter, preferably in plastic.
Auto gear lever.
Hydraulic regulator rubber coupling to the nylon low pressure leak off pipe. This is the reducing coupling.
Whatever else you may have.
Southerneruk
Re: wanted left wheel-house splash panel and rear washer jet.
Post by Southerneruk » Mon Dec 22, 2025 12:33 am
I still have a lot of stuff from the mark 1.6 that I broke up, if you got time come on down and I dig all out lay it out on the back lawn (it was 2.1 TDA estate)
Post by Dieselman » Mon Dec 22, 2025 6:35 am
No time at present, but a nice option.
I also want a 1992-1994 front scuttle R/h quarter trim in Hurricane grey and a good condition clock/temp display.
Southerneruk
Post by Southerneruk » Mon Dec 22, 2025 10:59 am
Let me know if/ when you have time, and we sort it all out, good luck in finding a clock/temp display I have been after one and the one on the other side for a long time (been trying about finding an alternative method)
Post by Dieselman » Wed Dec 24, 2025 6:29 am
2.1Td, top radiator hose.
Southerneruk
Post by Southerneruk » Wed Dec 24, 2025 10:38 am
I should have all 3 rad hose
Post by Dieselman » Thu Jan 01, 2026 11:17 am
Wanted...dashboard automatic gear selection LCD display.
Post by Dieselman » Sun Jan 04, 2026 6:51 pm
Wanted, Estate gas lifters and S1 glove box lifter.
Citjon
Orga / RP numbers: 8032
Post by Citjon » Wed Jan 21, 2026 2:02 pm
Are you still looking for the splash guard and wiper motor?
I may have the S1 rotary controls and auto indicator as well
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
Citjon
89 CX25DTR T2
72 D Super 5 Black
