150mph version for my 1999 Exclusive. It's not possible to change the card as it's firmly glued to the 'perspex' behind.
The electro-mechanical drive for the needle and odometers has an intermittent fault and there's no way to disassemble it at all. How do I know that's where the fault is? Because cruise control always works, so the speedo-head electronics and the transducer are both doing their stuff generating a signal, it's the little motor in the drive playing up - I can see what looks like a dirty connection through a transparent moulding, but the entire plastic assembly of the speedo-head is solvent-welded together...
WANTED Electronic Speedo
Old-Guy
- Orga / RP numbers: 08151CJ
Current
XM Exclusive V6 RP8151
Subaru Forester SH
Past Citroëns
Xantia 1.9TD SX estate (11 years)
Xantia 2.1TD VSX estate (11 months)
Previous (memorable)
Triumph TR2
Porsche 356 1600
TVR Vixen 1600
Alfa 1750 Berlina
Triumph 2000TC Estate
Subaru Forester SH
Past Citroëns
Triumph TR2
Porsche 356 1600
TVR Vixen 1600
Alfa 1750 Berlina
