XM 2.1TD parts for sale
kenhall
I have over 200 mostly new spare parts and some tools for sale for a late model 2.1TD.
I have added a list of available parts (apologies for the poor formatting!!).
Please contact me if you are looking for anything in particular.
Item Number-Parts for Citroen 1996 XM 2.1TD XUD11BTE hatchback (unless otherwise stated)-New Used Recon-Quantity for sale-Citroen part number for reference or alternative manufacturer details -Comments
3 Engine oil filter 2.1TD N 4 1109T1 / E149130 Citroen
4 Engine oil filter 2.5TD N 1 1109S8 / 1109AK Citroen
5 Diesel fuel filter 2.1TD N 12 190633 Early short type
6 Diesel fuel filter 2.1TD (Late) N 2 190655 Later taller type
7 Air filter element N 3 9401444108 / E147013 Various makes
8 Keypad code box and lid U 1 96020819ZL Citroen
9 Front suspension lower ball joint N 2 IRB364028 & SBJ14
10 Front brake pad set (283mm diam discs) N 10 95659640 Citroen, Ferodo, EBC, Delphi, Balco, AP, Direct & Abtex makes
11 Hydraulic hose from pump to regulator N 1 4023J6 For auto XM (BVA) with Aircon
12 Front brake disc pair (283 mm diam) N 3 4249L3 Citroen, Peugeot, Apec and Delphi makes
13 Rear brake disc pair N 2 95661814
14 Rear brake pad set N 6 425183 Citroen, Eurorepar, Delphi, Lucas, Motaquip makes
15 Rear brake pad fitting kit N 1 Lucas PFK11 Dust shields and bolts SOLD
16 Primary Handbrake cable N 1 96026870
17 Right handbrake cable 1230mm long N 2 96026873 Pattern make
18 Left handbrake cable 1030mm long N 3 96026875 Pattern make
19 Front n/s hub inc ball joint & bearing N 1 352089 Complete assembly
20 Front hub bearing N 3 335015 Citroen, Powertrain PTWB915, VBK makes
21 Rear hub bearing & flange assembly N 1 330767
22 Front ABS sensor ATE N 3 454552
23 Rear ABS sensor ATE U 2 454553
24 Steel wheel & bolts U 4 With worn (but legal) Michelin tyres
25 Wheel trim for steel wheel U 4
26 Spare steel wheel with good tyre U 0
27 Front brake caliper O/S N 0 95659638 SOLD
28 Front brake caliper O/S R 0 MINTEX SOLD
29 Front brake caliper N/S R 1
30 Lucas EPIC diesel pump U 0 SOLD
31 Lucas EPIC ECU U 1 Lucas NO CODE
32 2.1TD injector set recalibrated R 1 Lucas
33 2.1TD injector N 1 1980G0
34 2.1TD needle lift injector N 1 198029
35 Front suspension drop link N 2 508749
36 2.1TD Glow plug N/U 17 59623J 11x Beru GN013(N), 6xWellman W631(N) & 6x Beru GN909 (U)
38 Indicator + light switch U 1 625355
39 Dip stick U 1 117431
40 Headlamp N/S U 1
41 Headlamp O/S U 1
42 Fog + indicator lamp O/S N 1 630340
43 Fog + indicator lamp N/S U 1
46 N/S front wing primer N 1 7840F2 SOLD
47 O/S front wing silver U 1 Some rust at lower section but solid SOLD
48 O/S mirror housing primer N 1 815221
49 O/S mirror motor & bracket N 1 8148EZ
50 120 amp alternator 5 rib pulley R 2 EX57051Q
51 Radiator (Conrad fittings) N 1 1301Z6 Copper cored
52 Intermediate exhaust N 1 171751 Genuine Citroen SOLD
53 Rear exhaust box N 1 WALKER CN187
54 Rear exhaust box estate N 1 1726F1 Genuine Citroen SOLD
55 Alternator / HP pump ribbed belt (non a/c) N 2 6PK1100G Goodyear Gatorback 6PK1100G, PowerTrainPCMB061110
56 6 + 2 HP pump ex Xantia?? U 2
57 Water pump kit upgraded XUD11BTE N 1 1201C5 Genuine Citroen
59 2.1TD cambelt kit N 1 GOODYEAR K1G1284H
60 2.1TD cambelt tensioner N 1 81819 Citroen
61 2.1TD gearbox U 1 SCRAPPED
62 Front driveshaft outer boot kit N 2 CORTECO Complete with clips and grease
63 Front brake flexible hose N 1BENDIX 96037346
64 Track rod end 22mm dia N/S N 1 381743
65 Track rod end 22mm dia O/S N 1
66 Key pad latch N 2 7588FO Citroen
67 Heater core N 1 644889 Citroen
68 Strut top N/S 25mm diam rod N 1 As new
69 Strut top O/S 25mm diam rod U 1 Used serviceable
70 2.1TD hydraulic tappet N 12 94225 Citroen
72 Steerng wheel controls + air bag U 1
73 Front N/S sidelight lens U 1
74 Front O/S sidelight lens U 1
75 2.1TD auxiliary belt tensioner (non a/c) N 1 575138 Citroen
77 Diesel leak off pipe N 1
78 XM snow chains U 1
79 Glowplug controller U 1 598119
80 Clutch parts N 1 PEUGEOT 2050E0 Peugeot 605 2.1TD
81 Front ABS ring N 2
82 XM radio/tape player used U 1 Philips SOLD
83 Philips 6xCD player + lead U 1 Philips SOLD
84 Philips 6xCD player, no lead U ! Philips
85 CD player boot mounting bracket U 1 SOLD
86 EPIC diesel injector steel pipe set (3 only) U 1
87 Crank pulley extractor - home made U 1
88 Lucas EPIC throttle potentiometer U 1
89 Driveshaft nut + lockring N 1 Citroen
90 Pleiades pipe flare tool 3.5mm U 1 SOLD
91 Pleiades pipe flare tool 4.5mm U 1 SOLD
92 Cupronickel pipe 3.5mm X metres N 1 SOLD
93 Cupronickel pipe 4.5mm X metres N 1 SOLD
94 Pipe flare tool vice held type U 1 Old Pleiades type SOLD
97 Pulley extractor for EPIC diesel pump U 1
98 Nitrogen cylinder pressure reducing valve U 1
100 Starter motor R 1
101 Set of 2.1TD dash clocks U 1 Reset to 000000 miles
102 Serviceable spheres new and used N/U 12
103 Sphere removal tool U 1
104 Cupronickel Pipe 6mm N 1
105 Pipe fittings 3.5 + 4.5mm N Many Pleiades plated nuts 10 mm A/F Pipe nuts, seals
106 Citroen LHM+ I LITRE N 5 Citroen
107 Gearbox oil BV 1LITRE N 5 ESSO BV
108 MOSFET for suspension ECU N 2
109 XM Haynes manuals U 1
110 Revue Technique manual U 1
111 Peter Russek manual U 1
112 Lucas EPIC manuals U 2 Functional description and overhaul instructions
113 Steering rack n/s gaiter set N 1 406638 + 406630
114 Shims for Lucas injector pressure calibration N 1
115 Set of cylinder head bolts N 1
116 Gearchange rod 2454A6 N 1 245A6
117 Diesel larger filter housing Purflux U 1
118 Citroen O ring N 1 402687 Strut top seals??
119 Citroen O ring N 1 402688 Strut top seals??
120 Relays various U 10
121 Front strut leak off pipe N 1 95050399 Citroen SOLD
122 Heater fan resistor/contoller N 1 644178 Citroen
123 Front exhaust seal ring N 2
124 Power steering ram N 1 401135 Citroen
125 Brake doseur end seal / button N 1 95640067 MAYBE SOLD
126 Brake doseur overhaul seal kit N 1 Citroen MAYBE SOLD
127 2.1TD Timing belt N 3 Various Citroen, Dayco, Gates,Lucas and Veco makes
128 Crankshaft oil seal pulley end N 1
130 Lower suspension arm bush N 2
131 Camshaft oil seal N 1 23614
133 BEM Mueller hydraulic test kit U 1 Complete original kit
134 Lower front suspension arm N 1 352089
135 Crankshaft pulley/damper U 1
136 Suspension arm bush N 1 352357
137 Tie rod for smaller diameter track rod end N 1 381299 Citroen
138 Tie rod end small diameter thread N 1 TA1155 Lockheed make
139 Engine support yoke bush N 1 8003206 Sasic make
140 Sphere recharge tool U 1 Home made as per Noz design,requires nitrogen cylinder and regulator
40 Headlamp N/S U 1
41 Headlamp O/S U 1
Southerneruk
Re: XM 2.1TD parts for sale
Yes there are few bits I could do with, the LCD on both sides of the steering wheel
kenhall
No dash LCD displays available, sorry.
Lots of previous info on the forum regarding repair of the LHS display using conductive rubber strip to replace the failed printed circuit connector.
FarceAboutAce
- XM newbie
Hello - I could be interested in wheels, a radio, and the interior lock pin for the left rear door. Thanks very much!
1997 2.1td Exclusive auto hatch. RP CJ 7153.
kenhall
None of these available I’m afraid. Thanks for the enquiry.FarceAboutAce wrote: ↑Mon Nov 18, 2024 9:35 pmHello - I could be interested in wheels, a radio, and the interior lock pin for the left rear door. Thanks very much!
arcreha
- XM newbie
Is there a rear window defroster button and side mirror control button, thank you
kenhall
I’ve added a list of items - see my first post.
Davehedgehog31
- XM newbie
Hi, don't suppose you have a front passenger/left window regulator at all?
There's probably a few bits and pieces in this list I would like, I'll have a proper read.
Southerneruk
How much for the driver side headlight
