Roof Lights & Sunvisors
Saraphi
- Orga / RP numbers: 6834
I have enjoyed a fit of enthusiasm and decided to change the roof lining to Grey as I now have a set of leather/alcantara seat covers which the upholstery shop have started fitting. After placing the order it occurred to me that I really needed a set of 3 sun-visors, a sunroof centre switch panel and door lights/handles? all in light grey. Can anyone help source these please?
1995 XM S2 2.0i 16v - but with lots if Y3 bits
1995 Xantia 2.0 Exclusive
Re: Roof Lights & Sunvisors
Sunroof, or no-sunroof car?
What age is the roof lining? Early S1 had slightly darker , plusher grey lining, then S1-'92 on, then S2.
Saraphi
It's got a trouble free Sunroof, S2 original roof lining from 1995 to be recovered light grey.
Another question - are the components I need interchangeable between S1 and S2?
Yes they are, but colour and texture may vary, depending on the age of the donor car.
I believe 1992 on Series 1 are the same colour grey right through to the end of Series 2 and the only difference is the later S2 headlining has coat hooks built in.
The interior, console light is different between sunroof and non-sunroof cars, you want the square shaped one with the light lens in a H shape. The no sunroof one is trapesial and has a single light lens...i.e. completely different.
I have a number of S1 grey items... From various age cars. That be the roof console for FACTORY pressed sunroof cars along with the 4x side grab handles.. I'll have to double check on the backing trim though from behind the handles.
I also have grey mini sun visor thay sits forward of the roof trim
I'm Not sure I have the grey backing plastic from behind the grab handles. If I have I've not listed them in the stock list. They could still be attached to the roof linings I took out of cars. But I have all else.
Saraphi
Thanks, that's very encouraging - PM sent
