Box of Tct turbo parts..
In a look through the container I came across a tub with an small assortment of Tct turbo parts..
All of no use what so ever to me..
Consisting..
Throttle body
Exhaust heat shield
Engine ecu
2x alloy intake pipes
Idle valve. With pipes
2nd set of Idle control pipes
2x coil packs 1 set of. Leads
Couple link airn hoses
1x intercooler hose passenger side
1x wastegate electro valve and pipes
Small turbo outlet to air pipes link pipe
2x oil filler houses
Oil breather pipe
Whole lot 30 quid.. I'm trying to upload pictures but simple jpg pics are not liked by this stupid forum..
Anyone. I'll consider posting.. Export is a real bore now.. Not so much the sending more the customs forms..
Consisting..
Throttle body
Exhaust heat shield
Engine ecu
Oil breather pipe
Degens
Re: Box of Tct turbo parts..
I take it it would fit my blue car that you repaired?
Hi hans yes they are for Tct...
What would you like to do collect?
Degens
Thanks, I will talk with my wife what to do. Mr Drake is may be not so open for Dutch people living in England coming to Wales......
Every other English family has been over...
So it won't make a. Difference. But will need to be soon.. I'm possibly away a month from 7 June in hospital.
Degens
How much would it cost to post? And where are the items, so I can see how much driving and time I need to set apart.
I can get the box to the same place where I did your car.. Anglesey.. LL645QP..
There's some weight and there fore may cost too much to post..
Degens
Dear Paul,
can you please contact me on hans.degens@btinternet.com, as someone we know has family in Rhosneigr and is happy to pick it up before 4 june. If you contact me with your address and mobile number, then I can give you the contact details of that person. We will give the £30 to the person to hand over to you.
Best wishes,
Hans
Best wishes,
Hans
tibeam
- XM newbie
Hi. Have these parts gone now ? Thanks.
